Question about Initial HDTV-320 32 in. LCD TV
Recently moved to another city, lost the remote and can't find the code to program the DISH Network remote to get my tv off channel A 4
  • 246 Answers
Hi my nameis Mike Houston of DISH Network and I was going over your post and see youmoved and lost the remote. We have what we call a Power Scan for the DISHNetwork remote; it will allow you to get the code to the TV. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Posted on May 09, 2011
I have lost my dish set remote so how i can change the channels on the tv.i have tv remote.
if you lost your remote control for the dish simple call the customer service and asked for a new remote control. there are no ways to program a regular remote to a dish receiver box.
Feb 07, 2014 | DISH Network Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
I have dish network and need the remote code from the tv to activate the dish remote to change the channels, etc. And how do i program the remote to work with the tv
Hello! My name is Becki Barned with DISH Network. To program your remote, just follow these simple steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
500
795
816
Becki Barned
DISH Network Customer Service
Apr 06, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
I have a Nexxtech IT009 remote and a HTS Dish Network converter box. What is the remote's codes and how do I program them?
http://www.tivocommunity.com/tivo-vb/showthread.php?s=&threadid=128743
Above are all the codes for the HTS box,one of these should work with your remote.
Nexxtech codes below.
www.jascoproducts.com/support/download.../RemoteCode-4-digit.doc
Try using the code search to programme your device.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
3. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stayslit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again.
5. Press and release the Enter button to set the code.
If you still need a code list email, support@orbyxelectronics.com or call 1-866-363-3059.
Aug 13, 2010 | DISH Network IR Remote Control
TV IS AN ORION TV/VCR COMBO. THE BEDROOM TV IS IN RUNS OFF THE LIVING ROOM RECEIVER. THE TV CHANNEL IS SUPPOSED TO BE ON 60. NO REMOTE 4 TV, TO CHANGE CHANNEL TO 60. TRYING TO PROGRAM DISH REMOTE. 1 CODE 4...
zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
I programmed my dish network remote to turn my tv on and off,and after I programmed it I cant change the channels on the satellite it just controls the tv. The remote has a 21.0 on the back of it and my tv...
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Apr 25, 2010 | DISH Network IR Remote Control
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Initial HDTV-320 32 in. LCD TV Logo
81 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
