Question about Canon CLC 1150 Color Copier
Clc1150 oil on the copies can some one help
  • 4 Answers
You more than likely need the oil blade replaced. others things can be that you have paper jammed up at the top of the fuser which means youll need to open up the fuser.
Posted on May 07, 2008
Needing a free copy of the 158.16800 kenmore sewing machine manual. Needing help oiling it & geting cover off.
You won't get free copies I am afraid, only oil all the parts you can see or get to and use a very fine oil or wd40
Oct 26, 2013 | Sewing Machines
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
Jan 31, 2010 | Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
E0000-0132
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
regards
Jun 21, 2009 | Canon CLC 1150 Color Copier
Clc1150 cannot connect to fiery
Your Fiery need"s system software reloaded. let me know if you need help to do so.
May 11, 2009 | Canon CLC 1150 Color Copier
How can i get the CANON CLC1150 to boot up on service mode?
toner cartridge mixute problem
go on line type conan printer error e020 interkey
look threw the problems and see what you wannt to fix the problem best solves the problem
Feb 02, 2009 | Canon CLC 1150 Color Copier
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
E008 error code on canon
Brother DCP-8065DN Laser Printer no paper error please any solution for that.......!
Oct 21, 2008 | Office Equipment & Supplies
PSC 1510xi Squeaks badly when copy comes out
Hello Lujacques1,
You can download the user manual for your series printer here. It is free and in pdf format. This should help with your question.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Aug 23, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon CLC 1150 Color Copier Logo
74 people viewed this question
old marine
old marine
