Hi my Ariston Margherita LBE12X washing machine is not filling and just making a humming noise. we have checked the pipes and they are not leaking or kinked. Pls can you help?
  • 269 Answers
Have you checked the filter and drain pump for any blockages.If the pump cannot operate properly then it will not let more water into the machine.Also check the filters tn the ends of the hoses are not blocked.
Hope this helps.
Posted on Aug 28, 2010
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston LBE12X will not fill
depends which program you started with if you started with drain or spin then the humming noise you heard is the pump energised but jammed. remove the filter again and check nothing stuck in the pump impellor - bits of bra wire are the favourites if you started with a wash or rinse program, the humming noise is the inlet valve energised but no water coming thro. check water is turned on and hoses not kinked
May 22, 2007 | Ariston Technologies LBE12X Ariston
Smelly machine
problem is probably tjhat liquid detergent has been used - gives a smell loke drains. put on a boil wash without detergent and use powder detergent
Apr 05, 2007 | Ariston Technologies LBE12X Ariston
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
