Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
White screen with red and blue lines
My sons phone shows a white screen with blue and red lines going down the middle and i cant reset it...it shows nothing but the white screen and blue and red lines i cant see what numbers im dialing please help
  • 31 Answers
Try removing the battery for a few seconds and see if that clears up the issue.
If it does, be aware that it's most likely a temporary fix. You'll want to go through the phone and clear out some of the memory (saved text message, call log, and even pictures if there are a lot of them). You might want to consider stopping in at your carrier's local store and getting the software flashed as well.
Posted on May 07, 2008
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I dropped my blackberry 8520 and the screen has a line straight down the middle!!! i cant see anything..WHAT TO DO? the screen is white also
Sounds like you have a broken LCD screen. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry 8520 Repair Guide that shows how. Try to look for the Blackberry Javelin repair guide, it is very similar.
Feb 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
White screen with vertical red line, help
my blackberry has red blue line down the middle
Feb 03, 2010 | RIM BlackBerry Curve 8520 Smartphone
Dose not show on screen anymore. son said he was asked to change something. he did. cant play anymore.Must be some setting that was changed. Cant get it to show on T.V. TV says unsupported format. HELP
Not sure what you are talking about, this is a bit vague..... try this, on the back of the xbox there is a switch on the plug that goes to the TV, if the TV is not HI-DEF and you are using just the red + white + yellow plugs, then switch to TV, if your using the red + white + blue + green + red then switch to HDTV.
Your Son could have also switched a setting on the dashboard to use HI-DEF, if he did, maybe switching back the TV mode on the TV out plug may correct the issue.
Kids love to play with things! lol...
Sep 08, 2009 | Microsoft Xbox 360 Console
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
185 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
