Question about Electrolux Vacuums
Motor will not run appears to be switch or motor
  • Electrolux Master
  • 17,130 Answers
It is quite easy to check this out only if you can just have a multimeter with you.,
Take the panel of the vacuum removed too access the switch and the motor. use the meter to test for continuity of the wire to the switch and then to the motor if there is switching action on the main switch, the the power must come to the motor. however if the motor is not showing a reading , check if it is the brush type motor, if so clean the brush and commutator .or else the motor may need a replacement.
Posted on Aug 28, 2010
Sears kenmore vacuum 116.23401211C hardly used, suddenly no power at all. Cannot find manual, appears to be no fuse or reset on this model? Thx!
There is no fuse there is no reset either. If it doesn't run most likely the vacuum cleaner suction motor is defective or the power switch.
Feb 16, 2017 | Kenmore Vacuums
Bissell pro 2 brushes dont turn, belts are fine , shaft turns fine. how do i check the motor that turns these parts
You should be able to hear the motor running when it is switched on. If it doesn't make a noise then it isn't running and needs checking. If it does run be aware the drive belts can appear ok but sometimes considerably lose elasticity. so they won't drive. A new belt is often half the length and must be stretched to fit.
If the motor doesn't run and it is a corded vacuum it must be checked through with care. An internal break in the power cord is the most common cause of trouble with a faulty switch number two on my list and a faulty thermal breaker also in the top ten.
In the case of a cordless, first check the charger...
Dec 31, 2016 | Bissell Vacuums
I have a dyson animal dc44 it doesn't seem to be charging I have bought another battery but still making the same noise that the battery is dead and motor won't start :-( thanks Helen
The trigger switch, if not functioning properly, appears to be a likely suspect for this vacuum. You didn't mention what type of "noise" you are hearing, but if it sounds as though the motor is attempting to run then check to make sure you haven't picked up something that is binding the roller brush and preventing it from turning. If neither of these suggestions helps, you would would appear to have a motor or charger issue.
Jan 07, 2016 | Dyson Vacuums
Why does the motor run for 3 seconds then turn off?
Allan,
Can you give us some more info, like the make and model of your vacuum? That will help us give you better information as to how to fix it. Thank you!
Apr 28, 2015 | Vacuums
HOW DO YOU TROUBLE SHOOT A KIRBY G4 SWITCH?
can only replace with new switch to see if old one is faulty,
Mar 05, 2013 | Kirby G4 Bagged Upright Vacuum
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Motor will not start
You appear to be describing a case of motor brushes worn out. They may be replaced on some motors, but if there is damage to the motor armature (the rotating part the brushes contact) rhe brushes mayu not last long.
Mar 11, 2010 | Beam Industries 2775 Serenity Plus Central...
Shopvac 90L400 quit working (4 years old). Thought the switch was bad but not the problem. I read that there is a fuse link in the motor that frequently burns up. I tried to take motor apart but not sure...
by pass the switch and take power right to the motor leads.. that should tell you if the motor is ok.. have not seen fuse link on a vac motor.. graingers has new motors, but not inexpensive
Nov 30, 2009 | Vacuums
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Vacuums Logo
78 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
