Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
Click wheel problem
My ipod 20gb click wheel freezes and even if i try to reset it, but it does not work either..need help.
  • tazbe Jun 16, 2008
    I have a 40gb ipod and the click wheel has stopped working I have tried toggling the hold switch this didn't work help
  • Apple Master
  • 13,433 Answers
Have you tryed the 5 solutions from apple?
also found here http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Posted on May 07, 2008
Apple ipod stuck on now playing but will not go forward or backward. no sound
Best thing you can do is reset the ipod by holding the center and up on the click wheel to reboot. If that doesnt work do a fresh restore of the ipod through Itunes.
If that dont work find a repair service or replace the ipod.
Apr 17, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 20gb showing file folder with the triangle or Do Not Disconnect then after a few seconds will reboot, dont know if i can fix, or just throw away
Only suggestion I can make is to turn on and off 5 times last to on then hold down middle and top of click wheel till apple logo appears. This should reset your ipod.
Sep 25, 2009 | Apple 20gb Ipod Mp3 Player With Click...
IPOD SAY WWW.APPLE SUPPORT
It may need a firmware update, or the battery is bad. Try their site, I had success w/one of my ipod's with the same problem, now it works fine. Hope this helps.
Aug 17, 2009 | Apple 20gb Ipod Mp3 Player With Click...
CLICK WHEEL IS FROZEN
i m have a messae in my ipod:
HP DETECT
HP FAIL
Sep 04, 2008 | Apple 20gb Ipod Mp3 Player With Click...
My ipod 20gb freezes...and...
Since that you've tried resetting/restore method but no good still you can try to update the software of your ipod. Most likely the problem you've experiencing might have been caused by a corrupted software on your ipod.
First off, you'll need the latest version of iTunes.
If you don't have it already, go into iTunes, click Help and select Check for Updates.
After you are all nice and updated....
Connect the iPod to your computer and open iTunes (if not already open).
iTunes will see if a newer version of the iPod software is available, and prompt you to download and install it.
Follow any instructions that might come up.
The iPod display will display an Apple logo and a progress bar.
When this is completed, eject the iPod and check if it is now working.
May 06, 2008 | Apple iPod MP3 Player
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
20gb click wheel ipod
press the center button and up for about 6 seconds to reset. then go to your compter plug it in and reset back to factory defaults. Load the latest drivers and then reinstall your music. that worked for me.. hope it helps!
Jan 29, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 20gb trouble
t tells me to plug something into it, but it looks like a charger. i do that and i press the menu and the click wheel and the bettery level stays the same!
Dec 15, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
94 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
