Question about Boss 510CA CD Player
Won't turn on at all.
I hooked up this CD player in my 83 F150 & it worked for a day. then i went to crank the truck up the next day & it wont come on. I'v re-wired it and it still won't come on. I NEED SOME HELP.
  • Gorila C May 07, 2008
    I found the constant power source wire and hooked it up. somebody said that it could be the ground wire but i got it hooked up to.
  • 1,224 Answers
There is a memmory wire on the back of the radio which is usually yellow this needs to go to a constant source of power
red wire (power) goes to accessories black to ground
you need a test light to find constant source power wire in truck and to find an accessory line wire for red this should fix problem and dont forget reset button on radio after you done the wire fix
Posted on May 07, 2008
  • Brian Vickery
    Brian Vickery Mar 28, 2014
    where is reset button on a deh p77 dh
83 ford f150 6 cylender starts but wont stay running
It sounds like the carb is flooding the intake. Any chance the float is faulty or the carb is leaking internally ?
Mar 09, 2014 | 1983 Ford F150
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
I was driving down the road and the truck just died. it will turnover but it wont crank. i have a 83 ford f150 4 wheel drive 302 v8.
check and see if is getting any spark out of the #1spark plug wire .if not change out your distributor cap ,rotor button and spark plugs wires ,and plugs
May 18, 2011 | 1983 Ford F150
2001 f150 wont start change plugs and wires and now wont fire and wires are in correct order. can you help
Check your ignition fuse # 30, in the inside fuse box all the way on the right second from the bottom, check your coil and crank position sensor, these are responsible for spark, the crank sensor is bolted with 2 bolts next to the lower engine pulley, this is a magnetic pick up that triggers spark from the coil, if the crank sensor is good and you have no spark then the coil could be bad. Hope this helps, let me know.
Dec 14, 2009 | 2001 Ford F150 Styleside SuperCrew
1989 ford f150 cranks over but wont start, have replaced all the obvious stuff.
does fuel pump run when you turn key to the run gas cap stick in a funel put ear to funnel.. have some one turn key to run position......does check engine light come on when key in run position.......they have two very common problems....first the fuel pump relays and next very common problem is the ground for the ecm...main computer.....look at the battery then look at ground or negative wire you wiil see a smaller wire comming off the terminal. these will got to a bullet looking connector...cut out this connector and hook wires directly. even if not your problem it will be one day...write back if more needed
Sep 04, 2009 | Ford F-150 Cars & Trucks
Factory speakers on 95 camaro wont work.
loose wires a short behind ur reciever when ya put it in
Jun 16, 2009 | Alpine CDA-7894 CD Player
No spark 1991 ford f-150 5.0 EFI
check your eec wires on driver side under hood for shorts
Jun 05, 2009 | 1991 Ford F150
1990 f150 5.0 wont start
if the key was turned forward you burned the coil out or even the ign. module
Jan 30, 2009 | 1990 Ford F150
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
Boss 510CA CD Player Logo
534 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
