Question about Dell A940 All-In-One InkJet Printer
Printer wont power up, could it be the power adapter? if it is how do I find another one?
  • Dell Master
  • 17,129 Answers
If the output voltage is cheked it can be confirmed. It is possible tto repair the unit if it has failed. so opne it up and check if the fault is minor like the failrue of fuse in themains or in the secondary section . If so replace and test on printer to ensure it is not blowing out again. If so there is a powerr short onthe main printer board.
However If the adapter is not working evenif fuse is intact, it must be checked with a multimeter to confirm the fault .
Posted on Aug 28, 2010
My dell v313 printer has power to it and wont turn on
Often this is due to the power adapter going defective. Try another power adapter (available cheap on eBay). If this model does not have an external power adapter, it is probably the voltage regulator or rectifier in the printer itself and would not be worth fixing.
Oct 05, 2014 | Dell All-in-One Multifunctional (V313)...
Do the power cords go bad?
Check power adapter voltages.. If its dead buy new one, adapter voltages are good as mentioned on it, better to buy new printer, I wont suggest for major repairs in this printer series..
Sep 04, 2012 | HP Officejet 4315 All-in-One Printer
Printer wont turn on
Try to unplug the power adapter at the back of the printer and check if the LED light is on. If not, try to plug in the power cord to another power outlet. If still the same problem, the power adapter is the culprit.
If the LED light is on, make sure to plug in the power adapter all the way in the printer.
May 16, 2012 | Lexmark X4550 Multifunction Wireless Color...
OfficeJet 7410 wont boot up.
I would try resetting the power supply.
You can do this by unplugging the power adapter cable from the wall outlet.
Unplug the other end from the printer.
Unplug the power cable portion from the rectangular power adapter.
You should be left with a power cord, a power adapter, and a printer; All three are not plugged into anything. Leave it this way for 30 secs, then retry the turn-on process after plugging the cords back into where they belong. Also, try plugging straight into a wall outlet, and not into a surge protector.
If this is not working still, double check the outlet in question by testing it with an appliance like a hair dryer or lamp.
Bruce
Apr 02, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Printer wont feed paper
Try to reset your printer. Unplug the power adapter from the printer. printmastert_40.jpg
Wait at least 10 sec before replugging the adapter to the printer. Try to print again. If that doesn't help, there could be something in the feeder that's blocking the paper path. Remove the sheets of paper from the feeder and grab a flashlight and look inside.
Apr 27, 2011 | Lexmark X2550 All-In-One Printer
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
My printer wont turn on
Dear Sir,
If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU, SMC, or PRAM. Refer to the instructions for your model:
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to the nearest Apple Store or Apple Authorized Service Provider (AASP) for diagnosis. If you plan to visit an Apple Retail store, make a reservation at the Genius Bar using
Thanks For Your Time,
May 14, 2010 | HP PSC 1210 All-In-One InkJet Printer
Wont power on
try to replace its adapter because the problem mayb in the adapter not on the printer
Nov 29, 2009 | HP PSC 2110 All-In-One InkJet Printer
Printer x7350. power ok from adapter but wont
just check power connectors for printer side if it is ok may be fuse of printer burned.
Jul 10, 2009 | Lexmark Office Equipment & Supplies
My printer wont power on
For Canon PIXMA iP1800 series No Power issue. Normally is either QK1-3130-000 AC POWER ADAPTER or QY5-0194-000 LOGIC BOARD.
You may find the parts at www.comcentre.com.my
Nov 18, 2008 | Canon PIXMA iP90 Mobile Printer
Dell A940 All-In-One InkJet Printer Logo
22 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
