Question about Dual XDV8125
I have the dual xdv8125 car stereo and i hook all the wires up but nothn comes on. its hooked upto a 12volt dc power converter box. it wont do nothing at all.
  • Dual Master
  • 17,129 Answers
Make sure that the DC has more than 3/5Amps rating with good DC to make the set working. Test with a car battery to confirm your connection if not check the speaker connections, the main power, switched power and ground must be in order.
Posted on Aug 28, 2010
  • cdi19944 Aug 28, 2010
    O.K thanks i will try that.
  • Donald DCruz
    Donald DCruz Aug 28, 2010
    Please cast your vote if my advice has helped.
What do all hook ups do
You may download a copy of the installation/owner's manual here. The wiring diagrams begin on page 4.
Jan 12, 2013 | Dual XDV8125
Cant get the power to work on a xd1222
If the radio is correctly installed and, there is no power on the vehicle's accessory wire when the key is turned on, check the vehicle's radio fuse. If you connect the red to constant 12 volt along with the yellow radio memory wire the stereo WILL NOT TURN OFF. There is nothing strange about that.
Oct 14, 2012 | Dual Electronics XD1222 Car USB Player
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
I bought a amp lazar vibe225 when i hooked it up it works fine it when i turn my car of that the lights wont go off i got 2 12in dual spearker the blue light up kind bp1204 and i wired it from the amp...
In most vehicles, the speaker wires have 6v of DC on them. That could be part of the problem. You need to use an LOC (Line Output Converter). You should be able to get one from Wal-Mart, Radio Shack or any car stereo shop.
Nov 17, 2009 | Car Audio & Video
Dual XDV8125 car stereo wiring
CLICK HERE for a copy of your owners manual - install diagram is on page 5
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Dual XDV8125
Installing stereo had to put a wiring harness wired it all up red 12volt wire comes separete needs to hook up to ignition i do not know where it goes
Use a 12 volt test light & probe wires in harness from original connection, on feed side .Find a wire that only has power when you turn the key on. That's the one you'll connect that wire to.
Dec 26, 2008 | 2006 Chevrolet Colorado
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
May 21, 2008 | Car Audio & Video
POWER
Have you connected the remote wire from the stereo to the amp? assuming it has one.
If the stereo has not got a remote wire you can link it from the positive 12 volt on the amp to the remote connection on the amp, usually it's in between the ground connector and the 12volt.
Mar 22, 2008 | Lightning Audio LA1.300.2 Car Audio...
Dual XDV8125 Logo
96 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
