Question about Panasonic DMR-E85H DVD Recorder
DMR-E85H dvd video recorder. The problem is with starting up of the hard-disk. It takes an extremely long time to boot up, goes into self-check mode then switches off and on, repeatedly returning to self-check mode. Sometimes it may take several hours to become available. Strangely, if the timer record is active, recording still works, sometimes a bit late starting. Is there anything I can do, do you recommend trying formatting of the hard drive? Or is a service essential? If so, a costly one? Will it be worth it?
  • Panasonic Master
  • 11,800 Answers
The problem is caused by a faulty hard disk - it's dying of old age (non-recoverable errors), you should replace it.
No, it shouldn't cost that much, but finding a replacement disk will be difficult and time consuming. But if you're willing to take a gamble before junking it you could install a standard 160GB ATA disk in it, start the unit and upgrade its firmware.
The new firmware can be found here  ftp://ftp.dxcc.com/PANA_DVD.zip
Posted on Aug 28, 2010
Can I access the video saved on hdd of dmr-e85h with a computer? The power supply on the unit failed and I want to recover the recorded video on the hard disk drive.
you can pull the hdd out of the player and put it into another cabinet, either another player or an external hdd cabinet also known as caddys. you can buy caddys on e-bay or pc shops.
Mar 21, 2010 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
///// SELF CHECK /////
REPLACE THE PSU REGULATOR- STR6353
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
Record to disk
I was having the same problem and tried many different types of DVD-R (16x, 8x, even 4x thining speed might be the problem) finally went to the web page and downloaded the updated program. When I put that download into the disk drive the machine read it and the problem went away. Had not been able to use high speed before that either but it worked after the updated program was in it.
Jun 19, 2008 | Panasonic DMR-E85H DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Nov 25, 2007 | Panasonic DMR-E85H DVD Recorder
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
