Question about Refrigerators
Water on floor beneath aeg/electrolux upright fridge freezer [freezer at bottom
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Electrolux ide by side ESE6077SC fridge side leakes water near door corner. Dood does not seem to have much vaccum suction.
You either have a stopped up drain which can be confirmed if you have ice on the freezer floor, or the tube connector beneath the door is leaking.
Mar 28, 2013 | Electrolux Refrigerators
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
Feb 22, 2013 | AEG Santo 7085 KG Side by Side...
Water has collected and frozen at the bottom of the freezer compartment. From time to time I get small leaks on the floor beneath.
There is a drain tube from freezer/fridge and stops under the fridge and allows water to drip into an evaporator tray. The drain tube/hose can get blocked up, it is very common. Free up the tube and you will be good to go. Sometimes just snipping on the very bottom to make a larger drain hole works too.
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Constant build up of water at the bottom of the fridge - what can I do to solve the problem
Check if the pipe or hose that supply water for the ice maker is not leaking. Look in the back of the fridge at the bottom part to see if frost is building up on the pipe then melting and putting water on the floor. Build up of frost on the line indicates low on freon or something is wrong with the fridge. It will still get cold but the frost will melt and put water on the floor.
Jun 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
Fridge is freezing on the back but temp not high, water is pouring along the bottom shelf sides and onto the floor constantly, thanks
Freezer drain is plugged. Defrost the freezer and clear the drain line inside the freezer and in back where it exits the cabinet.
Jun 09, 2008 | Electrolux Refrigerators
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
