Blue light does not come on when unit is off - Televison & Video
  • 286 Answers
If the unit still works, I wouldn't worry about the blue light.
Posted on May 07, 2008
No blue light on Behringer Guitar Link UCG102
I have the same interface and also the light is orange rather than blue. Check this article where I quote:
"This (USB) light will be blue on older models of this unit and orange on newer models of this unit."
Setting up the UCG102 on Mac
Jan 13, 2014 | Behringer Ucg102 Guitar To USB Interface
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit
Jan 07, 2011 | 2003 Jaguar X-Type
Just bought B40 unit and in the initial set up there is no flashing blue light, just a blue light. Is this unit a lemon?
flashing blue lite means tank is out, or needs water..if you have water in tank re-seat the tank
Dec 19, 2010 | Keurig B60 Coffee Maker
I have a blue mark on the corner of my screen and several blue specks throughout the center of the screen. I changed the lamp thinking it was that but the blue is still there. What else could it be?
This is optic unit (light engine) problem, it has 3 color lcds and blue lcd along with related UV filters became defective and causing blue mark on front screen.
Need to replace optic unit (light engine) to resolve the issue.
Aug 20, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue lights on top of the unit won't turn off
Go into options mode and select LED BLNK to Blinking. This will return the lights to normal.
Jul 13, 2010 | XTR695 Radar Detector
No power?
i just picked up this same unit model and 1 thing is your backwards on the LED on/off...its blue when its off, and LED goes off when turned on.
Hopefully this will help determine if its off or on
RandyMan
**Life isn't about waiting for the storm to pass...its learing to dance in the rain!!
Jun 08, 2010 | RCA Audio Players & Recorders
Steady blue light, blinking lights doesn't heat up
I read in another posted solution about a magnet in the grey float that is in the water reservoir. I removed the grey float and rubbed on the front of the unit by the steady blue light and it apparently resets the sensor. Presto Magic! it worked! Machine back to normal and operating perfectly.
Jun 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
