I have a RCA P611960 the screen colors have sunk In the middle top part of the screen and the colors have seperated Blue,Red,Gray I need help...
  • 8,617 Answers
I would need to know the chassis number in order to help you, It should be located on the rear tag near the model number.
Posted on May 07, 2008
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
My RCA is concaving the picture in the middle and red green and blue are showing up seperately on the screen I also have A charter communication HD MOXI box connected to it but when I disconnect it the...
When you go to Menu then setup does it have convergences listed if not FL231 is bad Fuse 400ma.There is 3 only they do not look like Fuses they are small brown rectigular caps you can pull top off of them with Needle nose plyers it will be middle fuse ,look on right side of FBT there is 3 in aroll.
HAPPY NEW YEAR!
Jan 01, 2009 | RCA HD52W59 HDTV Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
