Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
On start up the computer fails to respond this has been intermittent but has got steadly worse and now will not come on at all. i do get light on the front and some noise from the computer
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 130 Answers
Well seems you have problem in bias.. or in start up of operating system, i recommend you first you try to start operating system in safe mode if possible otherwise you can also re install or say repair your operating system, this will solve your problem. and if still you facing problem after doing so then problem should be in your hardware so after that you need to assist your hardware engineer.
Posted on Aug 28, 2010
Service engine soon light is on, and the codes its giving are f110p and 1891p
P1891 20500 System Voltage High Input
This fault sets when the alternator is failing. But instead of failing where the voltage is too low it is too high. This is just as bad if not worse than too low. Your 7 series is full of computers and when they see this high voltage they start to go into failsafe to protect themselves. The overvoltage could even cause modules(computers) to fail.
Some modules very effected by this is the DSC control unit, EGS Transmission control unit. This type of problem will come and go due to the alternator is intermittently overcharging.
Now there MIGHT be other things going on but it ALWAYS is a bad alternator with the overvoltage fault in my experience. This alternator is a bit hard to do so I do recommend having the dealer replace it. Make sure you tell them about the overvoltage and even this post as most tech's easily overlook this fault and go chasing the "failsafe" problem and never stop to look at the big picture --system voltage.
I hope this information is helpful. Please accept and let me know if I can help you further.Thank you.
Jun 25, 2014 | 2004 BMW 745i
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
DiNovo Edge space bar and "n" key do not respond
I have the same problem with my dinovo after 2 years of usage, and i have found a temporary fix.
The temporary fix is to connect the dinovo to another computer and then hammer the keys vigorously, prefferably if dragging your finger over the keys, the keys will then start funcion immediately. Then connect dinovo to the first (main) computer again, and here the keys wont function, but after hammering them again vigorously it also starts working again here. However this is a temporary solution and the problem will probably reocurr. Notably hammering the keys on the first (main) computer wont yield any results even after long time of hammering without the second computer-lockup. Signalerror from logitech to specific computer? If there was dust this would never work on other computer so fast, and the error would not reocurr after being fixed.
Jul 18, 2012 | Logitech diNovo Edge 9676850403 Keyboard
Dash lihgts will not illuminite . Dash lights worked intermittently for awhile , but will not come on at all
Well.... other than GMC, I have no idea what kind of vehicle we are talking about. YEAR, MODEL, ENGINE SIZE, TRANSMISSION (auto or standard) and 4X4 or 2-Wheel Drive would be helpful in MOST cases if you are wanting specific information for your vehicle.
With all of that said, I can only tell you that I have seen several GMC models that have had bad solder connections at the wiring connector socket where it is soldered to the instrument cluster printed circuit. It usually starts out as an intermittent problem and gradually gets worse until things quit working all together. This can affect dash lights, gauges, warning lamps, turn signal indicator lights, etc., etc.
This could also be caused by a defective headlamp switch depending on which model and year we are talking about. Other models have dimmer switches that are separate from the headlamp switch for the dash lights. These can also fail and cause the symptoms you are describing.
Aug 20, 2011 | GMC Sierra 3500HD Cars & Trucks
I have a 2003 saturn vue 4 cyl. My security light has started to come on for only a few seconds when I put the car in gear and now is beginning to come on for a few seconds when I put it in park and goes...
When the security light comes on, it means that the Antitheft system is most likely begining to fail. It will start very intermittently amd progressively get worse until it either shuts down the car, or your car will refuse to start when that light is on. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 18, 2011 | 2003 Saturn VUE
I have changed ribbons several times but am still getting very light printing (not dark) on LQ-2090? This has been steadly getting worse. What could be the problem?
HAVE YOU CHANGED THE LEVER FROM 0 TO 7 ON THE RIGHT SIDE OF THE PRINTER? IF SO, RETURN IT TO 0 AND THE PRINTER WILL WORK.
Aug 09, 2011 | Epson LQ-2090 Matrix Printer
Audi A6 radio intermittently cuts out
I've had similar problem with AUDI A6. AUDI replaced phone controller, covered by 70% by manufacturer. Total cost 400 Euros, repir was done in Germany.
Aug 27, 2009 | 2006 Audi A6
1998 s-10 2.2l intermittent hard start
because you said it sounds like timing problems i may have an idea. i dont remeber if these have a distributer? but its common for the distributer on the newer GM trucks and i dont know why but its like the spark jumps around inside causing incorrect firing order when trying to start and just gets worse and worse. remove and inspect for build on on rotor and tabs on distributer.
and get back to me with problem
plz rate
Michael
ASE certified
Jan 30, 2009 | 1998 Chevrolet S-10 Pickup
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Acer AL1917 Monitor does not start up immediately.
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Nov 05, 2008 | Acer AL1917W LCD Monitor
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
44 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
