Quite cold even in full thermostat switch (cooler mode)
    Problem Solver:
  • 19 Answers
Check thermostat for proper operation. The thermostat could be stuck in the closed position. Moving the thermostat from warmer to cooler you should here a faint click.
Posted on Aug 28, 2010
Heaters in my kia Sedona blowing out cold air front and back
Check water/antifreeze level in radiator when the engine is cold. Make sure it's full.
If the level is full, the next thing to consider is the thermostat could be stuck in the open position. This would cause the water to stay much cooler for a longer time....thus no heat.
If that is not the cause, it could be the air temperature valve inside the air conditioning housing under the dash.
Not a real solution, but hopefully gets you on the right track to warmth.
Nov 30, 2016 | Kia Sedona Cars & Trucks
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
Prima water cooler just noticed that the cold water is not cold. Looked in back and copper coils all iced up.. turned off and put cut to collect water, what needs to be replaced> have another...
try to adjust to lessen the setting of thermostat maybe the setting is to full thats why the thermostat cannot cut off after the water chilled. then observe the unit.
Mar 02, 2011 | Vacuums
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
Cold water never quits trying to cool water. runs
Hello, this is going to be a bad thermostat. This is located behind the grill in the back. It has 2 electrical wires and a metal wire that goes to the tank, you should replace it. Hope this helps! Mike
Oct 30, 2009 | Hamilton Beach Water Cooler with Storage...
Cold water is freezing
if ur water cooler is freezing there could be two different things wrong, one yes is the thermostat, the second how ever is a relay switch located at the bottom of your cooler.
need any help? omilian.jos@gmail.com
May 04, 2009 | Hamilton Beach Water Cooler with Storage...
Salad prep cooler too cold I turn the t-stat up or down compressor still running I think the t-stat is bad don't you think?
It sounds like the thermostat is "stuck closed". Try unplugging the cooler, MAKE SURE ALL POWER HAS BEEN DISCONECTED. Remove thermostat cover with thermostat on it. Carefully pull one of the wires spade connectors off the thermostat. Insulate the end of the wire you disconected with electrical tape. Now plug the cooler back in. If the compressor stays off the thermostat is the problem. Let me know if that helps. I know of a common replacement cold controll for that unit:)
Apr 05, 2009 | True Refrigeration Mega Top Sandwich Salad...
A/C Heater problems
the main issue with this is either the thermostat or the climate control switch I do not know if your climate control switch is electronic or manual either way I would start out with the cheapest and go with the thermostat first good luck!
Nov 22, 2008 | 2004 Chevrolet Impala
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
