Question about Vacuums
I have a sock stuck in the hose of my vacuum cleaner. Rennaisance canister model. Because of the design of the handle I can't utilize the reverse blower. Please advise. Thanks
  • 286 Answers
Lol
Try taping a fishing hook or some such onto the end of a straightened out coat hanger. See if you can push it up the hose and hook the sock.
Or, remove the hose entirely, and push a broom handle down the hose.
That's all I got...
Posted on May 07, 2008
How do remove the plastic elbow on the hose. A sock is stuck in hose
put it on the blower and try to get it out backwards. Usually works
Feb 24, 2016 | Electrolux Lux 7000 Bagged Canister Vacuum
Why doesn't my dirt devil vision turbo have any suction through the hose yet there's good suction at the hose connection to the canister?
The hose is probably blocked. If possible reverse it (put the intake of the hose on the canister connection) that should suck out the obstruction. If that fails try to carefully push a broom handle into the hose, preferably from the end that connects to the canister. Put the hose back on normally and see what happens.
May 22, 2015 | Dirt Devil Vision Turbo W/Bonus Upright...
How can I separatte the ****** handle of my Epic 6500 fromthe hose? I have a wrapped pair of socks stuck in it at the handle
There are two different styles of hose for the 6500 vacuums. Please be careful when you take the handles off and also when putting it back togeather. To remove the handle there are two screw caps that you need to remove to get to the screws. You can do this with the tip of a knife or something similar inserted under the edge of the screw cap and pry up. The screws can either be a Phillips head or a torx bit. Remove the screws and then separate the top part of the handle from the bottom. Make sure to notice the position of the wires and do not unplug them from the switch or the contact block.The contact block at the hose end of the handle has two contacts that transfer the power from the hose to the handle and will bend out of shape if you are not careful. To remove the contact block, use a flat head screw driver under the block and pry up. On the older models, the handle will slip right off. If you have a newer model, there is a handle retainer at the base of the handle and will push out with a screw driver. It only goes one way and
the handle will slip off.
To replace the handle just reverse the procedure. Good luck.
Aug 28, 2014 | Electrolux Epic 6500 Vacuum
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
I have a sock caught in the vacuum cleaner hose it is about 5 ft past the beginning of the hose and very stuck I have tried sucking it to the canister but no luck please help the suction is almost too good...
take a coat hanger and straightn it the best you can then make a small hook on one end of it and if you can unhook one end of the hose straightn the hose and try to go fishing with the coat hanger.
Mar 20, 2011 | Vacuums
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
My Dyson DC20 motorhead vacuum has a blocked hose - how can I unclog this? I think there is a sock caught up by the handle. The hose has electrical wires running through it so I cannot cut the hose.
Usually a plugged hose can be cleared using a broom handle, if you can force the blockage through, if not as previously suggested a coat hanger attached to the broom handle (duck tape will do) straighten out hanger so it can be used like a cork screw to screw into the blockage and pull it out, socks,underwear and pantyhose are the usual suspects!
Nov 06, 2009 | Dyson DC05 Cylinder Bagless Canister...
Stuck sock
first off how did u get the sock that far..lol but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Dec 30, 2007 | Electrolux Lux 5500 Canister Vacuum
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Vacuums Logo
141 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
