Question about Creative Labs SoundWorks SW320 Computer Speakers
One of the speakers which is connected externally s not working..what do i do...??
Can external speakers be used with the sony cfd s 350 model? If so, do they plug into the headphone jack on top of the boombox?
There is no provision for connecting external speakers. The headphone connector is exclusively for connecting headphones.
Mar 02, 2015 | Sony CFD-S350 Radio/Cassette/CD Boombox
HOW a 36A41 model's External Speakers Work ?? ...
Your speakers may be plugged into outputs intended for connection to an external amplifier.
May 04, 2014 | Toshiba 36A41 36" TV
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
External speakers don't work
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Dec 10, 2012 | Televison & Video
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Creative Labs SoundWorks SW320 Computer Speakers Logo
18 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
