Question about Tally T2265 Dot Matrix Printer 917402
AGA error in T2265 printer - Tally T2265 Dot Matrix Printer 917402
3 Suggested Answers
  • 169 Answers
SOURCE: Printer-Genicom 2280+ Printer stopped then
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Posted on Sep 21, 2009
SOURCE: Hi There. I have Tally
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Posted on Mar 10, 2011
My printer display Aga error when it power on, what is the solution?
AGA means automatic gap adjustment, it probably means it can't handle the paper properly. try adjusting the paper carriers and reloading the paper.
May 14, 2014 | TallyGenicom 2280 Matrix Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
T2250 giving error in harware alarm code +0000ne-w81 000 000000002 - 4032
Check whether AGA Gear working Proper or not OR giving noise after power on printer
If AGA Gear not working proper insert the steel rod in AGA gear properly
Oct 27, 2010 | Tally T2250 Matrix Printer
Hai , i have tally 2280 sprintpro printer.now it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
or
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
Fault AGA sensor.
To disable the AGA
Jul 21, 2009 | Tally Matrix T2280 Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
484 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
