Question about Daewoo DTQ-20U4SC 20" TV
Circut diagram of power supplies using STR5707
  • Rommel Cana
    Rommel Cana Aug 28, 2010
    while i am still searching for your schematics,
    have the horizontal
    output transistor checked first ( while you do not have a power? )
    post back what you found , if is OK ( resolder Vertical circuits too,
    (only if
    possible )
Power falier
Posted on Nov 21, 2010
How do I start my daewoo without key with chip in it
None of that will do you any good. You need that chip. Dealers can cut a new key with the coded chip. Takes a VIN# and registration. Prove you own the car.
Dec 14, 2015 | Daewoo Cars & Trucks
Power supply bern i want thosiba model no: 2168tiv circute data sheet
Schematic diagram are in PDF, and cannot upload by this window. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Power supply section circuit to some popular brands are given.
Nov 05, 2013 | Toshiba Televison & Video
I need canon gp 405 Service manual that contain circut diagram as follows :- 1) IP Board ( Image processor PCB) . 2) DC - Controller . 3) CCD/PCB 4) Composite Power Supply . 5) Main Motor PCB . 6) Fixing...
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Jul 31, 2010 | Canon Office Equipment & Supplies
My lg 42lh20 has power but will not turn on
hello, there could be numerous reasons for this, mainly a power supply that has a fualty part or over heated circut, basically something went bad, these circuts are very delicate and they operate at very high temps this cuases circut fualts. just one bad resistor or blown capacitor may cuase this, it seems you may want to start at the power supply, the way i go about repairing these sets is by aquiring a service manual for the particular set then checking that the voltages are proper at the output terminals and check points.
the service manual for your set may be downlaodable, if your not electronically inclined you may want a service tech to check. it if your able to perform these types of checks use a service manual.
Jun 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Photocopier fuses hi my name is redha i would to have a definition of fuse in the photocopier in general the location and tha function ASAP Please Thanks
Redha,
Fuses are located on the power supply and some control boards.
In general fuses are used for circut protection when the load exceeds what the circut is capable of handling the fuse will blow to hopefully protect the circut and the board. This is a very broad definition.
Hope this helps
Apr 18, 2010 | Gestetner DSc338 Copier
I am looking for a diagram of a 9 volt wig wag circuit, for a pair of n-scale train crossing lights, can anyone help me out.
if you just want the light to blink use a flasher reley and a circut cut reley if you wire it properly it will flash
it is simple to wire it
there are 2 output wires and 2 input wires on the power reley just hook the flasher reley to the power wire and conect the lights up to eithor wire coming from the reley
remember the reley will require power and ground the litess are hooked positive side to the reley and neg to the neg wires of power supply
Sep 16, 2009 | Kitchen Appliances - Others
AVS500 Woofer has low Freq.pulse.front and back speakers working. Need circuit diagram to trouble shoot . Henry
Is the power supply AC or DC. I had a similar problem with my boston acoustics speakers, and I was able to swap the power supply for a DC output one of the same voltage and amperage and the hum went fully away. it is an inverter circut that went bad in my woofer.
Jun 13, 2009 | Altec Lansing 621 Computer Speakers
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Hisense color TV ±74cm, Model TC2919H
I HAVE A PROBLEM IN THE PRIMARY POWER SUPPLY STAGE HAVE CHECKED ALL COMPONENTS AND RELACED STRG96...IC AND OPTO COUPLER .
CAN U LET ME HAVE A CIRCUIT DIAGRAM?
Sep 04, 2008 | Televison & Video
Daewoo DTQ-20U4SC 20" TV Logo
694 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
