Question about Toshiba Satellite M45-S331 Notebook
Toshiba M45-S331, Black screen
I am having the same problem as someone back in Dec. '07. I turn the laptop on and see "Toshiba", then the screen goes dark. I tried, as you instructed then, taking the battery out, pressing the power button for 20 secs. and then waiting one minute. Powered back up and the same thing happened. Any further suggestions?
  • 1 more comment
  • aggie91 May 13, 2008
    Thanks, but didn't do the trick. I powered own and restarted while push F8 to start in safe mode, "Toshiba" showed and then went black. I've tried FN and the F5 key at the same time, again, to no avail. Thanks, again.
  • plcsc Jun 26, 2008
    The Screen is very dark and on an angle I can see a little. On some re-starts it came back with standard brightness. I have not been able to duplicate this again. With an external monitor the screen is perfect
  • Sanjeev1956 Jul 16, 2008
    I had problem with Toshiba M45-331 Black Screen problem. When I started the laptop two days back toshiba screen comes and goes up immediately. Then I removed the battery and run on AC Power. It worked for two days and having same problem again. Somebody please give me a solution for this problem because it is affecting my work because I am working from home
I just went through all this myself. First I had the inverter replaced ($200) and it worked great for a week, then the screen went out again. It turned out that the LCD needed replaced ($200 more, labor comped from the first no-fix). There's a problem with the Toshiba LCDs that makes them burn out sooner than other brands. Since the replaced screen, no problems (2 months). Sucks, I know.
Posted on Sep 15, 2008
    Sergeant:
  • 324 Answers
Can you get it to go into "Safe"mode, and if so, will it come up then?
Ron-
Posted on May 08, 2008
When my m45-s331 laptop is turn on for a long time, if i put the monitor off, maybe in not be turn on again and it's brightness become very low and hardly it can be seen! what should i do?
if you're using win xp, try to check the power option.(click start, go to control panel & power management/power option).from there, you have an option to adjust your screen brightness settings everytime you wake up your system from sleep mode/hibernation mode.
other option, you can update your video driver. here's the link http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882862&rpn=PSM40U&modelFilter=M45-S331&selCategory=2756709&selFamily=1073768663
then choose display driver. download and install it. It will update your video display driver. It might help to improve your brightness issue.
Good Luck,
Ryan
Jan 17, 2011 | Toshiba Satellite M45-S331 Notebook
I changed the inverted in my toshiba satellite
Sounds like the screen itself is bad or possibly the plug is bad to the inverter or motherboard.The videocard sounds like its ok.
Oct 03, 2009 | Toshiba Satellite M45-S331 Notebook
When I turn the computer on the screen doesn't work
This is the monitor not being attached to the Graphics Card properly.
Sep 14, 2009 | Toshiba Satellite M45-S331 Notebook
2nd RAM slot for Toshiba Satellite M45-S331
if its not under the laptop, it can only be under the keyboard.
Jun 18, 2009 | Toshiba Satellite M45-S331 Notebook
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
I dont find sound drive for this mdel
hi
go to this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1, click Download
2, select laptops
3, select satellite
4, just scrol down you will fine M45-S331
5, and select go
6, select operating system
and download
have a nice day...
Jun 02, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba M45-S331 Won't Boot and Broken LCD
Solution Replace the Monitor screen which cost around 60$
Apr 02, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba M45 S331 power issue
Try this, remove the power supply and battery. Let it sit for about 15 minutes then re install the battery and power supply.
Oct 06, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 Notebook Logo
649 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
