Question about Maytag M7DH45B2A Dehumidifier
FOR THE DEHUMIDIFIER WHEN I OPEN I THE BREAKER JUMP WATH IS IS.............
  • letilou Aug 29, 2010
    II EXPLAIN WHEN PUSH THE BUTTON FOR USE THE BREAKER OF ELECTRIQUE JUMP....IS THE SAME THING EVERY PLACE IS IT A SHOT CUT INSIDE ....WHAT I CAN DO.....THANK
    MARIE
  • Maytag Master
  • 19,396 Answers
Hi, that means that there is a short circuit in the Dehum. Check the power cord, if power cord is OK, then the short is in the internal curcuit. The unit must be disassembled and tested by a technician.
To book repair call the number listed on the owners manual.
Posted on Sep 01, 2010
  • Maytag Master
  • 12,061 Answers
This means you have a short circuit, or a short to earth. This is the ONLY thing that can or will trip a breaker. Be careful, as machine may be live, if breaker doesn't blow, and up until the time it does.
So check, wall cord, check switch, check element, check for shorts across the Line.
Posted on Aug 30, 2010
  • 3,083 Answers
Could you please supply more information, I don't understand what the problem is...
Posted on Aug 29, 2010
When dehumidifier is turned on the circuit breaker trips. everytime the dehumidifier is started model LHD65EBL
Hi, Compressor is bad... tripping the breaker...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 06, 2011 | LG LHD459EL Dehumidifier
When I plug it in and turn it on it trips the breaker. I have tried other outlets but it does the same thing.
Hi, The compressor is locked up and is bad... that is what trips the breaker...
heatman101
Jul 31, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The amp blew in the DD50PC Delonghi and we need to replace it. What is the amp?
rmbm521 - I would like to help you, I have been offering solutions to humidifier problems for some time. But, I have never heard the term "amp", as would apply to a dehumidifier. In most general electrical terms "amp" or "amps" is the amount of electrical draw or use that an electrical appliance uses. It's short for "ampere".
I don't know where you heard it, read it or who told you that. But, they may have been referring to the circuit breaker , that's in your home's circuit breaker panel,. The one that feeds the outlet, the dehumidifier is plugged into. If that's the case, was your dehumidifier tripping one of the circuit breakers in you circuit breaker panel? If that's the case, they meant, the circuit breaker was not rated high enough to carry the load of dehumidifier, when it was in operation.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | DeLonghi DE50P Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
When power on keep blowing the circuit breaker.
The compressor is bad... this pulls too much current and blows the breaker...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 24, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifier throw breaker
Sounds like the compressor and if it is that oyu are better off buying new...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 13, 2010 | Comfort-Aire BHD-651 Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
Goldstar dehumidifier keeps tripping the circuit breaker in the house
your problem may be within your dehumidifier or it may be within the circuit breaker itself. I just replaced a faulty breaker this morning for a customer.
plug the dehumidifier into another plug which you are sure is working and also sure is not on the circuit you have been using. [turn that breaker off and you will know what it controls
if the problem is the breaker, replace it. if the problem is the dehumidifier look for a poor connection, a bare wire touching the frame of the dehumidifier, a fryed wire, etc. good luck.
Sep 09, 2009 | Dehumidifiers
Trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Oct 17, 2007 | Goldstar DH504EL Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
42 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
