My computer has been shutting of be itself lately now it will not boot up at all, can you help?
    Sergeant:
  • 203 Answers
Hi, maybe a number of many things unfortunately. Have you installed new into your computer? (RAM, Graphics Card ,etc...).
If so take it out and restart the computer and see if it will boot up. If this is the case then you probably need a more powerful Power Supply Unit. If nothing has been added then a possibility that the Power Supply Unit is now failing, computer is overheating - check vents are not covered up with dust, objects etc.., the thermol paste between the Processor Chip and Heat Sink may have dried out and lost the contact between them, Motherboard could of failed.
Like I said before it could be a number of things but these are the most common.
Posted on Aug 28, 2010
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
I have a dell inspiron 1525. The computer has not been charging correctly lately and most of the time only works when plugged into the wall. The computer now blinks 4 orange then 1 blue light on the...
> blue light on the battery
This is an indicator that the battery has reached its "end-of-life".
There do exist companies that will disassemble the battery, replace the rechargable cells, and reassemble it. Or, look on eBay for a replacement battery.
> the computer will also not boot up
That's a quite-different problem, and probably NOT related to the problem with the battery.
Jul 19, 2011 | Computers & Internet
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
I have a new sanza e260,which shuts down my computer
Try re-installing the drivers for the MP3 player FIRST then plug in the MP3 player! Also make sure you have the lates Windows media Player installed
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Volume control
Try to boot into Safe Mode (windows 7: press F8 on boot, or Win10: start: type msconfig, enter, then boot tab: [x] Safe boot, press enter). It will be more successful more often in Safe Mode, but whether you can get into Safe Mode or not, click Start, type System Restore, press enter. (You may have to go to System Properties: System Protection tab, then System Restore.) When you restore to a previous restore point, you may find the weirdness to go away. If your problems are due to malware having been installed, you may have to choose restore points further and further back in your restore point history until you get back to before the malware, then the badness goes away. System Restore does not affect your data, only the Windows files.
Apr 03, 2017 | Qtronix Scorpius 98N Plus Keyboard
Re boots itself
when you turn on the pc keep pressing F8 and it will boot into safe mode. When in safe mode highlight the option 'Last Known Good Configuration' and press enter. The pc should now reboot normally, if not you will need your installation cd to do a system repair.
Mar 18, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
