Question about Onkyo TX-DS939 Receiver
I'm staring to think this is a problem within a logic circuit but maybe something else I hope.
  • Rommel Cana
    Rommel Cana Aug 28, 2010
    you might be needing to have a signal tracer, or a small amplifier to confirm, your electronic
    circuits ( power supply in particular seems to be OK ) seems OK , here is your guide :
    sample troubleshooting
    http://www.fixya.com/support/r4008719-di...
    , use the schematics to guide you or post should
    you need more assistance
  • davesahim Aug 29, 2010
    FIXED! I'm so happy!!!!!!!! I soldered in a new jumber for the -12Volts and and its working again! No I don't have to pay 500 bucks like last time to get this thing fixed again.Thanks you the help.
I had a long eyecontact with an aries?
aries when they look at you they get confused weather it was his confusion or you are really staring at him/her so they keep on watching you which you can say as long eyecontact
Jan 04, 2017 | Horoscopes
Fuse 18 keeps blowing
Once a fuse blows,it does so for a reason
Common Sense
In a 60 year driving career you have maybe 6 fuses blow
Replacing them 5 out of 6 time they blow again
Ask yourself why
You need to find the most logical item in that circuit
& start testing & that usually requires a wiring diagram
or you have no map or now where to start any testing.
Something overloaded a circuit find it & replace it or
resolve the wiring issue
Aug 03, 2013 | 1994 Ford Mustang
Logic board
I just cant hear my songs, it is playing but I am not hearing anything.
Apr 04, 2013 | Apple iPod MA446LL/A MP3 Player
1997 Jeep Grand Cherokee Laredo It turns on then sometimes it turns off as I put it on drive or it gets stalled. It also makes a funny jerking-jumping move while on driving as it is going to turn off or...
Thats where i would start more than likely its over do for change anyway.Then check your fuel pressure no matter if its a 6 cylinder or 8 cylinder it should be 44-54 psi with key on engine off.If not within specs replace pump.HOPE THIS HELPS!!
Apr 21, 2011 | 1997 Jeep Grand Cherokee
How the microprocesser function
Features
  • Microprocessors have become the movers and shakers of our everyday world. We use them in computers, televisions, watches, microwaves and practically every other electronic device. Their micro-size is no reflection of the myriad capabilities these chips possess, ranging from 2 to 3 mm square to maybe an inch thick. Silicon makes up the material of a microprocessor chip. Sliced wafer thin, silicon serves as an ideal conductor and insulator for Function
  • A microprocessor is the central processing unit in a computer. It receives, transmits and coordinates every command and process carried out by the system. Electrical currents, moving through wires and transistors, are converted into usable messages through the use of a Boolean logic language. Based on the "on/off" frequency of current moving through transistor circuits, this Boolean logic communicates system commands to and from receiving devices within the computer. The microprocessor communicates within two primary capacities: logic and the processing of information. These processes are handled by two components within the chip:
    *Arithmetic logic unit (ALU), responsible for all commands requiring an arithmetic or logic function
    * Control unit (CU), which handles the information processing from the computer's memory
  • From these units within the chip, clusters of wires called "bus" lines send and receive information to and from system devices.
  • Oct 16, 2009 | Computers & Internet
    How do i fix my game cartridge if it has cracks on it
    Is it just the plastic casing? If it is just the casing and not the circuit board, I would imagine using a little super glue, or even tape!
    If it does not run because there is a crack on the circuit board within the cartridge, then I think you'd be better off getting re-purchasing the game used at gamestop or something.
    Hope this helps,
    Bill
    Sep 04, 2009 | Nintendo Game Boy Advance SP Console
    Jvc av-65wp55
    thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
    Dec 23, 2007 | JVC AV-65WP55 65" Rear Projection...
    JVC 65 inch projection tv
    Nov 29, 2007 | JVC AV-65WP55 65" Rear Projection...
    Blue Haze
    Apr 30, 2007 | JVC AV-65WP55 65" Rear Projection...
    Onkyo TX-DS939 Receiver Logo
    57 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
