Fisher turntable mt 6410 removal
I need to remove the turntable in order to replace the belt. the turntable lifts slightly and then sticks. Is there a release button?
  • 3 more comments
  • davidod May 08, 2008
    the mt 6410 fisher turntable does not have a ring lock in order to get the platter off
  • Carlos Luis Varela
    Carlos Luis Varela Jul 03, 2014
    ONLY PRESSURE TO DO GUIDE AND PULL UP TURNTABLE PLATE. MUST APPLY SOME STRENGTH IS EVERYTHING!
  • Steve
    Steve Feb 13, 2017
    I just tried this with my mt-6410. You just have to pull really ******* the platter and it pops off. I put my feet on the base to hold it down, stuck my fingers in the two larger openings, and just pulled.
  • Steve
    Steve Feb 13, 2017
    Not sure why there are asterisks in my comment. It should say "You just have to pull really ******* the platter and it pops off."
  • Steve
    Steve Feb 13, 2017
    Well, that's weird. Anyway, just pull on the platter hard enough and it will come off.
    Sergeant:
    Champion:
  • 319 Answers
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
Posted on May 07, 2008
    New Friend:
Posted on Jul 03, 2014
I can't get the hand vac to separate from the regular stick part. How do I remove it? I'm pressing the release button and it frees it slightly but something towards the bottom is stuck.
Press the release button, pull the top out from the stick (the electrical contacts are a little sticky at first) then lift it out. The lip of the dustbuster juts out a bit at the back so lift up to detach it.
Nov 29, 2017 | Televison & Video
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Fisher mt 6250 I need a replacement stylus. What will fit my turntable?
    Hi, your Fisher MT6250 takes a Pickering XV-15 stylus. We have them in stock. cheers john. Stylus City
    Jan 25, 2014 | Audio Players & Recorders
    Stanton str8-20 belt size???
    HI,
    If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
    OK
    Dec 11, 2012 | Audio Players & Recorders
    How do i replace belt
    On this model in order to replace the belt first disconnect power to the dryer. Looking at the front of the unit in the seam between the front panel and the dryer top, use a putty knife to press in & release the spring clips in the right and left sides of this seam to release the top panel. Lift the panel & rest it against the wall. Reach in & remove the 2 screws holding the front panel to the side panels. Once you have removed the screws, lift the front panel up slightly to remove the complete front panel from the stationary clips at the bottom of the dryer. Be careful with the wires going to the door switch. Either remove them from the switch or simply lean the front panel against the right side of the cabinet. Next, lift the drum and slide the new belt around the drum to the mark made by the previous belt on the drum. Be sure the ribs are facing down. Part number for the drive belt is 31531589 which over the years crossed to 341241. On your knees, reach back by the motor and idler assembly and lift the idler pulley tension arm to route the belt allowing the idler to take up the slack in the drive belt. Reassemble and dryer some clothing.
    Mar 24, 2012 | Maytag PYE2300AY Electric Dryer
    I just bought a aiwa turntable & stereo at yard sale. the old lady said she never used it but yet the turntable will not turn. i've looked over the manual and can't find any troubleshooting. can you...
    Hi Denise, I am in the consumer electronics repair industry. It may be as simple as this... Lift up the MAT on the turn table. This is the black rubber covering that you place the record on. Look through the holes in the plastic turntable (rotate if necessary) until you see the motor/pulley shaft sticking up (brass color). The turntable belt may have dislodged from this pulley. If you see the black flat rubber belt near here, just put it around the pulley again. Make sure it is not twisted and sits flat. Spin table by hand to be sure it is seated properly.
    Now you may have to remove the plastic turntable itself if you can't see the belt right away. In this case, remove the C-clip with a flat screwdriver (be sure not to lose it) from the record center post. Lift the turntable plate up shaft. Check to see if the belt is still partially around the plate. You may be able to just see enough to wrap the belt around the motor pulley now. If you need to take the plate off completely, then just place the belt first around the groove on the plate and finese the belt around the motor pulley. Now seat the plate, replace the C-clip and place the MAT back on and it should be good to go.
    I had this same problem on a new turntable I got for free. Good luck : )
    Oct 17, 2010 | Audio Players & Recorders
    Can't remove platter after removing lock washer
    It should just lift off, but might be a little stiff.
    Jan 04, 2009 | Aiwa PX-E860 Turntable
    1,185 people viewed this question
     Grubhead
    Grubhead
