Question about Samsung DVD-M105 DVD Player
I have purchased a Samsung Series 4 LCD TV. Connected my DVD-M105 using red/yellow/white cable, but connect get full colour - only variations of red or blue (or b & w). What am I doing wrong? Thanks, Warren Smith
  • Warren Smith Aug 29, 2010
    Hi -
    Have played around with connections (unsuccessfully) - colour now red/green (no blue). Sound OK.
    DVD connections - Y/R from Component Video out - W from Analogue out.
    TV connections - Y - Component in (y), R - Component in (Pr). W - Audio in.
    Best connections I can achieve. No luck in being able to locate setting change on TV.
    Warren S.
  • Samsung Master
  • 11,800 Answers
Most likely ther's something wrong in the settings - this happens when you get a Composite ( yellow)signal in a Component (yellow+ blue+red) connection.
First of all make sure you have selected the correct plugs on both the tv and the dvd - the yellow/video composite + red/right + white/left should be in their own separate box. Then check that the cable is correctly plugged in. Finally check that the tv is set to use the Composite, not Component AV entry.
Posted on Aug 28, 2010
  • Azrael SRL Aug 29, 2010
    Almost all the connectors you have tried to use are wrong. First of all the connectors on the dvd must be these: Yellow - Composite out, Red and White - Audio (right and left) out - they are together.
     On the tv you must get these : Yellow - Composite in, Red and white - Audio (right and left) in - again they are next to each other. What you did was to plug some cables in the Component connectors - resulting in a very messed-up signal.
    Once the cables are correctly plugged in all you must do is to select the correct AV entry .
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
LCD TV connection to DVD-VCR
OK here is a possible solution: 1) The best solution: Connect the antenna to your DVD-VCR through the RF Input and the the RF Out to your TV This take care of the VCR part. Then you get an RCA three way cable (Video-yellow marked, Right Audio-Red marked, Left Audio-white marked)connect the yellow marked RCA cord to the Video out of your DVD player then connect the other end to your video in of your TV. Ater that connect the red marked audio cable to the R Audio out of your DVD player to the R Audio in of your TV do the same for the white marked Audio cable. You will now be able to switch from VCR-RF to DVD-RCA.
Sep 11, 2007 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Apr 03, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Samsung DVD-M105 DVD Player Logo
111 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
