Main power flicks off when starting my simpson esprit 750 washing machine
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Aug 28, 2010
Hi, got a Simpson esprit 750 washing machine. Pulled power cord out from main board when moving it. Can you tell me where the brown and the light blue wire reconnect please. Earth is easy.
They go on to the timer. On the end of the timer is a row of terminals with other blue wires on them. They are all the neutrals, put the blue wire on one of those end terminals (any one that is empty)
There is a terminal in the centre of the timer marked A. That is where the brown live wire goes.
Jul 08, 2017 | Simpson Washing Machines
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
I have esprit 750 been amazing and still is going strong BUT I have started to get black like oil marks on my sheets. What is this from. What should my husband be looking for.
The upper water seal for the bearing is not holding...will need to replace the water seal & possibly the bearing due to water infiltrating the bearing.
Feb 22, 2015 | Simpson Esprit 750 Top Load 7.5kg
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
Sep 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
Why won't my washing machine agitate
I would suggest either motor coupling or motor starting capacitor .replace capacitor first as is easy job if it still doesn't work check motor coupling . these are probable causes . capacitor about twenty five aus dollars
Jun 08, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
