Question about 477L Ask RXTX HHU Remote
How to diable start timer. My truck turns on every morning at 834 and it shows a 24 hour clock on my remote
  • 662 Answers
Is this the model number ???? 477L
Posted on Aug 28, 2010
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Setting the clock
To set the time, turn and hold the Timer knob to the clock
symbol = and at the same time turn the Adjusting knob left
or right until the clock shows the time of day. Remember this
is a 24-hour clock. Let go of the Timer knob and it will spring
back to the vertical, oven manual setting.
Dec 05, 2012 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Does portable air conditioner made by LG have a 24 hour timer? model # LP0910WNR. If so how do I program it? Thanks
Maximum models and brands having 24 hrs timer. And yours also one of that. If you have clock in your remote keep in what time it should be on and off. If no clock, Press timer on it display as 00.00. Press < or > till you get 24.00. Helpful?
Dec 30, 2010 | Heating & Cooling
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
477L Ask RXTX HHU Remote Logo
349 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Morgan Kane
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
