Question about Dean Evo Xm Electric Guitar
I dont know how to rewire the back of my dean evo xm? i tried to fix the faulty input so i thought the wires were faulty so i tried to rewire it and i dont know where everything goes now. theres red yellow and black wires.
  • Dean Master
  • 5,603 Answers
It is rare that wires would be faulty. Soldering can be, but not the wires usually.<br /> <br /> Common problems are broken jacks or pots that are broken or shorting to the paint in the cavity.<br /> <br /> If you have things unwired now, the best thing is to find an appropriate circuit here and wire it like that:<br /> <br /> <a rel='nofollow' href="http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/">http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/</a>
Posted on Aug 28, 2010
Need to see the wiring diagram for dean evo xm
Here's the diagram.
You probably don't even have 4 wires from each pickup, because the middle ones are already connected.
Jan 25, 2013 | Dean Evo Xm Electric Guitar
Ground wire is not attached
okay. the ground needs to travel through all your components.you have the -input jack, - vol. & tone pots, the -switch & all - pick ups. All should meet at the body ground. Usually there is a wire that comes from the saddle, through the guitar, and enters somewhere in the access in back. (remove the plate that cover your vol. and tone pots). Good Luck
Dec 04, 2011 | Dean Evo Xm Electric Guitar Natural...
I did not get a manual with my Evo XM guitar and amp pack, and my experience with electric music making is limited at best, so here is my basic question; what are the functions of the two knobs and the...
I don't know precisely, but since it is a dual humbucker and only has 1 switch and 2 knos, the knob nearest the neck is probably the volume, and the other is the tone. The switch should select which pickup is in use, towards the neck for the neck or rythym pickup, and the other way for the bridge or lead pickup. If it has a centre click position, that will be both pickups on together. If one of the knobs has a pull position, that will likely be a single coil switch for the lead pickup.
May 03, 2011 | Dean Evo Xm Electric Guitar Natural...
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
If the wiring is correct on the guitar, try plugging it in to a different amp. If you still don't get any sound, the problem may be a faulty volume or tone potentiometer (or pot. The knob, for simpler words). These are fairly easy to replace if you know how to solder. If not, then watch this video: http://www.youtube.com/watch?v=BLfXXRfRIzY
You can get the pots from Musician's Friend, Guitar Center, or any music store that carries guitar parts.
If that doesn't fix it, then the problem is in your pickups. You can get "aftermarket" pickups through the above mentioned dealers, and you're not restricted to the original pickups.
What you replace them with will affect your tone, so do some research before settling on a set of pickups. Active pickups will give you more gain (great for nu-metal and hi-gain applications) and have lower output noise, but they require batteries. Passive pickups have no need for batteries, but tend to produce slightly more noise and hum.
Hopefully, it's the pots. That will be the cheaper fix, since they run about $2-$4USD each. Pickups can range from $100-$500USD a set.
Hope that helps!
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
2 wires came disconected inside guitar need to know where the go.
hard to say without seeing. are the wires coming from the pick ups? Or Input jack? or?
Jan 08, 2011 | Dean Vendetta XM Electric Guitar
I need a schematic for a dean ml shadow
Try this site:http://www.seymourduncan.com/support/wiring-diagrams/
Mar 19, 2010 | Dean Guitars Dean Ml Xm Electric Guitar
I need to wire the input on my vendetta
The positive wire is usually white and the ground is black. The ground goes on the tab that connects to the barrel that the guitar plug fits into and the positive is the tab that connects with the tip of the plug.
Jul 30, 2009 | Dean Vendetta XM Electric Guitar
Dean Evo Xm Electric Guitar Logo
117 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Rick Moore
Rick Moore
Tom Rood
Level 1 Expert
Are you a Dean Music Expert? Answer questions, earn points and help others
