Question about Sharp Aquos LC-32D40U Television
Cc tech so when the technician came by what ended up happening? was it a simple matter of loose screws? i hope so because my tv has just started showing these symptoms.
Sorry for the delay in responding. But, yes, it was a simple matter of some screws. The technician took my TV down from the wall, opened up the back, removed and set aside some parts, and then replaced the screws in question. Since then, the TV has been working just fine. The tech said there was a bulletin put out by Sharp on this (apparently it's a common problem). I don't have the work order on me right now, but I can come back later tonight and post the specific part name and location of the screws (and order number for the screws.)
Posted on Jun 12, 2008
Feed dog timing
It would be in the Service Manual for your machine. That is a common adjustment that technicians make quite often. It's usually a matter of loosening one or two Allen screws, adjusting to the correct position, and tightening the screws again. Sounds like over time, the screws in your machine have worked themselves loose.
Mar 05, 2014 | Singer 2662
I have a Polaroid 32" LCD TV/DVD combo -
is very simple u have active the close caption mode on ur remote control , this happen sometimes , on ur remote control look for a botton that it said cc or caption or cc mode press this botton till it said on the screen on ur tv cc off or u would see c1 , c2 but u whanto have the one that it said off and that would fix this black box on ur screen
Dec 31, 2010 | Polaroid Televison & Video
TV doens'nt start
Take to repair shop, must have a loose connection. I am an electronic Tech, 20 years experience. When you turn on a late model TV they do a self test and if they detect a problem then they shut down. I'm not really up on LG, I work for Panasonic and our LED's flash, and depending upon number of flashes it tells you where the problem is. I would suggest phoning LG for the address near you of their Authorized Service Agent. Get the guys who fix them everyday to do the job.
Cheers
Gordon.
Sep 27, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
May 14, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Tv will turn on but nothing shows up
here is a simple test to know whether to call a technician,...first, check all connection including the antenna or cable lines to your unit.if not, tap the unit for 2 to 4 times.while tapping watch what happens to the picture.if the unit turn on or becomes okay, i suggest to call a tech.it needs resoldering or something inside has loosed contact.
May 11, 2009 | Apex Digital GB4308 43" Rear Projection...
Hitachi 51SWX20B projection TV has no picture or sound
first lets check the remote to see if its working , with a digital camera facing the front end of remote (where THE EYE is) look thru the camera screen while pressing any button from remote , you should be able to see FLASHING LIGHT coming from the remote. SECOND about your TV , better off to have unit check by an authorized tech . hope this helps
Apr 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
JVC HD-ILA (HD-55G456) Lamp has to be re-positioned everytime TV starts up
Not the same problem, but I have the lamp light and power light blinking simultaneously and haven't figured out that one yet
Mar 28, 2008 | Televison & Video
PHILIPS TV 32PT6441/37 SHUT DOWN
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Philips 32PT6441/37 32" TV
LG tv - have lost picture, have sound.
Is this a relatively simple thing to fix,
no it is not that simple.
 it so expensive that we should just buy another TV?
no it is not expensive.
no need to buy new tv.
smell might be due to short circuit of some components which may not be that expensive
better to call skilled tech for fixing
 it is not a major problem
it happens so many times.
hope this will help.
good luck.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
