Question about Asrock K8Upgrade-1689 Motherboard
Installed new board
Well i installed this new board with a harddrive that had vista already installed it acts like it wants to boot up then it reboots any ideas?? Do i have to do a reinstall? if i do will i lose all my settings on the old os???
  • 2 more comments
  • pchrist May 07, 2008
    i simplified it down it gets to the boot from the old drive and it won't start it goes so far and crashes. I want to do a repair on the os but it won't boot to the cd. It is listed in the boot options as to boot to it first but it won't go from it??? Any help????
  • pchrist May 08, 2008
    I am going to try and rebuild it tonight. I was having issues with it recognizing the hard drives. Going to install vista 64 bit version tonight. That would be the correct version to install correct?
  • pchrist May 12, 2008
    This board is not recognizing my sata drives??? it is also only seeing one hard drive attached??? What can i do??? Please help
  • pchrist May 14, 2008
    the bios is only seeing a 8048mb for a 200gb hard drive????
    Please help
    Genius:
  • 1,019 Answers
Check the settings in the bios.
Remove all un-necessary devices such as printers-external drives et,c. setup the machine with bare essentials, this will give the computer less to setup and configure.
also if you have 2 or 3 sticks of ram, reduce to 1 stick or swap to different slots.
Check with the motherboards manual, regarding any jumper settings or setting up/Configuring the Systems Bios.
Mike @ compurepair.
Posted on May 07, 2008
  • Mike Waldron May 08, 2008
    I,m not great With The Vista Operating System.
    Always Used Win 95/98 ME And XP.
    I do know there are lots of issues with Vista And Drivers et,c.
    I personally think, that your trying to install from a hard-drive that has data relating to the previous system or motherboard it came from.
    the only suggestion i have, is to try some recovery software. or find out if theres a system restore button F8 Or similar to restore to previous settings.
    if it,s similar to XP. When the operating system is Written To The Drive. it configures itself to Those Components.
    If you take out a hard-drive and install it into another system. it will fail to boot.
    usually the only way. is to reformat the drive. and setup the operating system from scratch.
    Mike @ compurepair.
  • Mike Waldron May 12, 2008
    if your board is not recognising sata drives. it will probably be that they are not setup or enabled in the systems Bios.
    Enter The Bios Setup, according to your User Manual.
    In the Bios, you should have settings to adjust. use primary or secondary IDE Channels Or Both.
    If you have 2 hard-drives on 1 IDE Cable, set the jumper blocks, on the rear of the drives. as master and slave.
    or put 1 hard-drive as slave, and the cd rom drive as master.
    Also ensure that your motherboard, has the installation cd.
    this may have the sata drivers on it.
    mike @ Compurepair.
I have put new hard drive in - When booted up it says - Reboot and select proper boot device or insert boot media in selected boot device and press a key.
there can be two scenarios
1. the harddrive is not installed properly
2. the harddrive is not selected as the first boot device in the BIOS of the computer.
After you install new harddrive, you will have to reinstall the Operating System in the computer as well.
For further assistance, log on to HNetworking.com and use Online chat option
Admin
HNetworking.com
Feb 03, 2011 | Computers & Internet
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
To install xp with vista in compaq presario cq45 207tu
Even if you manage to install Windows XP, you will not find the drivers for sound/video because this operating system is not preferred by the manufacturer.
Hope this helps. Thanks.
Jul 22, 2009 | Computers & Internet
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Brian
Jul 09, 2009 | Intel Computers & Internet
Satellite L305-S5907 locks up.
If your computer boots then lockup, try this:
When your computer boots, press F8 to enter boot selection. Then select Safe Mode. Try to uninstall your newly installed software or hardware that might be causing the problem. Then reboot. If it persists, try using "Last Known Good Configuration"
Another option is to reinstall your OS. Last bad option though. Good luck
Jul 06, 2009 | Toshiba Satellite L305-S5907 Laptop
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite 1115 S103 can't install Windows XP home edition
after it reboots it will ask you to boot from cd,
ignore this and let it boot from harddrive, where it has already copied the files to... it should setup ok from there
Apr 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Asrock K8Upgrade-1689 Motherboard Logo
47 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
