Question about Maytag SDE2606 Electric Dryer
How do I replace the heating element in Maytag Dryer SDE2606AYW Serial# 12508837EN
  • 155 Answers
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
Posted on Aug 28, 2010
Hwant schematic for Maytag dryer model YMEDE301YGO
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Mar 05, 2015 | Maytag Dryers
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have an old Maytag dryer and its model # is LDE8800 and the serial # is 201878 DU and there is no heat in the dryer cycle anymore. It runs but doesn't dry anything--any help? thanks! Ali
Need a new heating element. had a look around cant find one for yours, maytag did recall a lot of heating elements due to severe problems. they are not a very good brand. i think the model is too old for a new element. Time for a new dryer i think. try Hotpoint or LG
Dec 01, 2010 | Maytag Dryers
Hello, my maytag neptune dryer runs, but will not dry. where do i find the serial # ?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. serial # should be inside door jamb!
Jan 01, 2010 | Maytag Dryers
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
My maytag neptune dryer is not drying/ what do I do first
to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
Dave
Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
No heat
Dryer Heating Element
Oct 29, 2008 | Maytag Dryers
Maytag SDE2606 Electric Dryer Logo
273 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
