Question about Hilti TE 7-C 120V Rotary Hammer Drill
I have a Hilti TE 2-S , so I removed the head to installed a right angle attachment .Now the hammer takes the bit put does not lock it . I reinstalled the head in this sequence 1 bearing washer spring boot keeper ring 1 last rubber boot. What should have been the correct sequence?
  • 90 Answers
Check for a schematic at diplodocs.com
Posted on Sep 01, 2010
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hi i have hilti drill machine i dont how to open and removed the drill bit,please help me
what you need to do is twist the collar of the chuck to remove bit and reverse the procedure to lock it into place.
Aug 03, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I need to remove the chuck assembly from Hilti TE16 c
With the palm of your hand over the chuck where the bit goes in take your fingers and pull the black sleeve right at the drill casing and pull towards your palm. After you have pulled it all the way back just pull the whole chuck off.
Feb 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
I have an old hilti, model: te 12 s. it wont drill. when i press the botten it only hammers. i have tryed to open the machine but i can not find the problem.
IT could be one of two problems. 1 The Rollers are missing out of the chuck so that it is not turning the bit. 2 the clutch is worn out causing the gears to slip. The problem is there are no longer parts available for the 12S. You would have to find them on Ebay or some place like that.
If the bit seems to lock into the chuck then it is not the rollers. It is more than likely the clutch.
Aug 08, 2010 | Hilti 375847 TE-CX 3/4" x 12" Masonry...
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 7-C 120V Rotary Hammer Drill Logo
143 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
