Question about SanDisk Sansa e260 MP3 Player
Music in Micro SD
I am not able to index my music in the Micro SD by folders (Albums), plase help!!!
  • Mario50 Mar 26, 2009
    Thanks!!!!!!
Go to Settings > USB mode ..Select MSC
You get TWO vert.Drives in your brouwser on PC
The one with WMPInfo.xml on it ...
Create your maps there .. and check MP3 tag for artist etc..
It will merge in your database after ... disconnect ..
Posted on May 23, 2008
I downloaded my music files to the micro sd and went into my music and it had no content exists. music is on the micro sd though can you help me step by step
Access your card from your computer and take note of the files.......your cell phone creates different folders for different menu options.
The folder should be music, but depending on your carrier could be labeled as sounds.....all files should be moved to this specific folder....so 1: access the media card 2: mover the media contents to the appropriate folder 3: your ready to go :)
another option is the copy the entire contents of the card to a folder on your desktop and format the card from the settings menu in your phone..............now you can look through the folders that the device creates to determine the one used for music......
geeeze.....hope i didnt lose you there
GOOD LUCK!!!! & Please Rate This Post!!!!!!!!!
Oct 02, 2009 | UTStarcom Cell Phones
MicroSD does not contain supported music files
1. Install the sd into the phone.
2. Go to Menu > Settings > USB > Mass Storage
3. Connect the MotoVE240 to your PC via USB
4. Under My Computer open drive (E:).
5. Find the folder that has your music in it. Example: My compter made a folder called Music.
6. Drag music from that folder to the my_music folder. (the phone will only read music that is in this folder.)
7. remove your phone from the usb
8. press the music note on your phone and enjoy your music
Jul 13, 2009 | Motorola Cell Phones
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
Apr 27, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Putting Mp3s on LG Envy 2
Brandon,
1st - Place the SD card in the phone. 2nd - Adjust the setting to save Pictures, Video, Music to the SD card by going to Settings and tools > Memory > Save Options. 3rd. Remove the SD card from the phone and connect to PC. Now on the PC you will see the phone has created folders for you "Music". 4th - Drag your music files into the correct folders (ie music, pictures, etc). 5th Place SD card back in LG Envy 2 and enjoy the music.
Kevin from SLC, UT
Mar 30, 2009 | LG enV VX9900 Cellular Phone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Feb 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
SanDisk Sansa e260 MP3 Player Logo
149 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
