Question about Bosch Turbo Jet Bagged Upright Vacuum
My bosch turbo jet vacuum
I was given this vacuum and it runs but the brushes don't turn can you help?
Open the head. there is a dc 120 v motor with a belt.
check for ac power going in to the rectifier board and dc comming out.
sometimes the black wire breaks inside the motor housing.
it is hard to open and close the motor housing side where the wires run and closing the power head is fun as well.there is a transformer for the light and wires have to be routed just right to close it up.
good luck
Paul G. Canada
Posted on Jan 08, 2011
  • pgazo Jan 09, 2011
    I forgot to add that power to the brush motor also goes. through the micro switch located in the handle.That has to be checked as well.
    Next to the gray ON OFF switch.Since you are a new owner you might not know what that switch was for...
    Good luck
    P.
Hi can I order a new hard floor turbo brush for a nv350nz26
HI, it's Jim from Crucial Vacuum!
If you're looking for a high quality turbo brush for your Shark NV350 as well as other replacement parts for your Shark we offer a wide variety for a low cost.
You can purchase your replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
This link will bring you to our Turbo Air Vacuum Brush Tool.
http://www.crucialvacuum.com/turbo-air-driven-brush.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 10, 2014 | Vacuums
My bosch 1450 vacuum does not have suction
Have you changed the bag lately? If not, I would try that first. If so, then check to be sure that nothing is blocking the pathway of the suction area. Check those two things and if you still have problems, come back and let us know.
Sep 16, 2014 | Bosch Turbo Jet Bagged Upright Vacuum
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
The brush won't turn. Any suggestions?
not a expert just trying to help,, check and see if brush turn by hand,, if so take bottom plate off and check belt to see if it is broke,,hope this help you
Oct 20, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Kirby Legend 2 Vacuume cleaner
call Francois Gordon 27 11 476 1235
Rocky
Jan 03, 2009 | Bosch Turbo Jet Bagged Upright Vacuum
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
I have cleaned all of the hoses...replaced the belt ...
Check the inlet down by the brush roll, it is probably clogged. You might change the belt also if you never have, I am sure it is stretched.
Jan 22, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Bosch Turbo Jet Bagged Upright Vacuum Logo
138 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
