I have a MIts VS-70803 and just replaced a leaky capacitor on board location C910 200V 820uf. Turned the TV on and a loud buzzing noise coming from somewhere then poof my new capacitor went up in smoke. What could be causing this problem? What are some other parts to check?
  • 22 more comments
  • Eric Boklep
    Eric Boklep Aug 28, 2010
    This is a rear projection Tv.
  • Eric Boklep
    This capacitor that blew is in front of the convergence chips STK392-040 (if looking in TV from the rear). Before it blew I had picture and sound. And it was hot as heck. From turn on to blow up took about 25 secs. I also noticed a resistor that was out of the board on location R8D22 which i put back in the board. (It was out when I had the buzzing before the capacitor replacement, then I soldered it back in upon new install of capacitor).
  • Eric Boklep
    Eric Boklep Sep 02, 2010
    Ok I'm not sure here but I am testing these resistors and am a little confused. The resistors read Green Blue Gold Gold, which means 5.6 ohm resistor correct? They all read 2.0, 2.1, 2.2. Are these all bad? Thanks
  • Eric Boklep
    So I'm testing these resistors here is what going on. The resistors read Green Blue Gold Gold so it is a 5.6 ohm +/-5% correct? They all read 2.0, 2.1, 2.2 are these bad? And if so are there other parts that could have made these go out? Thanks
  • Eric Boklep
    I tested these resistors and am a little confused. The resistor reads Green Blue Gold Gold which means 5.6 ohm at /- 5% correct? They all read 2.1 or 2.2 are these bad? If so are there any parts that I should test that made those go bad? Thanks
  • Eric Boklep
  • Eric Boklep
    So I'm still a newcomer to this but they are marked on the board IC921 and IC922 are LM2576T-12 QFY831, IC900 is STR F 6626 SK8626, IC401 is LA7845 8U O, IC402 is 9805H 74HC14AP, IC403 is MC74HC74AN JAM9847L. Or these ICDB01
  • Eric Boklep
    Ok the ic's are marked icon the board right? What #'s do you need off of them? The ICBD01 and 2 #'s are STK392-040. Not sure if my replies are getting to you they are not on the solutions area of what we have discussed. Thanks
  • Eric Boklep
    Wow I thinking I'm just overloading my brain. Now for checking these ic's, what do i set my multimeter on? And these ic's are 5 pin LM2576T-12 Do you know what readings I should be getting? Or do you know a good place to find this information? I feel like I'm asking to much from you. Thanks again
  • Eric Boklep
    Sorry caroldon I do not know how to rate the comments. Could you tell me how? And for whats happened so far not sure if you have all the info...Turn on TV the first time and a loud buzzing from somewhere, found a leaky capacitor 820uf 200V a resistor was out of the board and re-soldered some of the STK392-040 pins. Replaced the capacitor and the buzzing was still there after 45 secs or so the capacitor blew same 1 I just put in. I tested all the resistors in the row that had 1 out of board by STK and all on other side by STK they are all bad 16 total. So this is where I am at. Thanks
  • Eric Boklep
    A resistor with Yellow Violet Silver Silver is a .47 ohm /- 10% and they both read .6 are these bad? Thanks
  • Eric Boklep
    What does marking on circuit board D8D83, R8D82,Q8D83 etc double letter ?
  • Eric Boklep
    The STK chips have 21 pins and are really big I thought these were the convergence chips. Or am I wrong? I'm starting to think I'm in way over my head. When I started this the TV does work but only for less than a minute. Should I just order all the IC's and the resistors I found bad 20 the capacitor, also found a couple diodes? On another note diodes should only read 1 way correct? Thanks for your time
  • Eric Boklep
    eagle338, every time I reply to you I click add comment for you. Am I not doing this right? And I do know terminologies although not very well. Am just confused on the wording is all. Remember I am new to this and I do appreciate your help very much. Updates of my journey of fixing this beast found 2 diodes that are bad D-911 just beeps both ways and D-912 reads 453 1 way and then 1809. And I was reading up on buzzing and humming noises, is it possible that the noise is the color wheel or a fan coil or transformer? And another when looking down at the crt fluid should you see the color? Thanks
  • Eric Boklep
    eagle338, on diode test with the red to black to - meter reads 457, with red to - and black to meter reads 1812 board locationD912. D911 just beeps so that is bad correct? Also while testing transistors CB pin should read 1 way, CE pins should read 1 way( how close should the measurements be), and BE pins should not read either way? And as far as the flyback transformer how do I identify that and test it if need be? Thanks again
  • Eric Boklep
    It does not show V mV or anything just a # meter is set on diode check and also has a continuous symbol. I guess I would have to say its in Volt where my rad lead plugs into the multimeter. Sorry I'm really starting to get discouraged but dont want to quit. Thanks again
  • Eric Boklep
    to all would any of the bad parts resistors capacitors diodes transistors cause this buzzing or humming noise? The noise is not coming through the speakers it is in the tv itself.
  • Eric Boklep
    eagle338.....OK so all these parts failing together is causing the buzzing? I guess I just want to know where the buzzing is coming from. What part to be exact. Just getting a bit frustrated. Did you ever happen to come across the service manual? Thanks
  • Eric Boklep
    I just ordered the manual . I know its hard to teach over the computer but I do appreciate everything you have done. My friend got me into this repairing electronics stuff. And now that I try to stay home and do stuff he doesn't give me any straight answers about testing things and what he thinks may be wrong. Thats kinda why I get impatient at times. Hopefully this manual will help me out to. I will keep trying things and be hittin you up more. Thanks again
  • Eric Boklep
    Eric Boklep Sep 08, 2010
    eagle 338, got my service manual yesterday. wish i knew how to read some of that stuff..maybe you could give me some pointers as how to read some of that nonsense? Found another bad capacitor... how do you go about ordering the right diodes? it only gives you the mitsubishi part number and the description stf14. Thanks
  • Eric Boklep
    Eric Boklep Sep 09, 2010
    eagle338 , I figured the diodes out (they are printed wrong in my manual STF14 supposed to be sft14)got lots of parts on the way. As far as pointers mainly what certain parts of the board do. Per DBF , DEFL-MINI, JUNGLE, PWB-RGB of coarse I'm sure if I really looked at it I could figure it out. Thanks for all your help.
  • Eric Boklep
    Eric Boklep Sep 11, 2010
    Hey eagle338, Was wondering if you could do ma a favor if you have the schematics for the VS-70803 Mitsubishi? The 2 capacitors that were bad are at board locations C910 200V 820uf on the PCB-Power board Hot Chassis and C9A08 200v 820uf on the PCB-Main Hot Chassis. Could these 2 capacitors which I believe are in circuit with each other be the cause of the buzzing noise? Or There are 2 IC's locations IC900 STR-F6626 on Power board and IC9A00 STR-F6628 on main board. Question would these cause the caps to blow? I just got the caps to replace them and Ido have the IC's ordered. Just wondering if these are IC's that control the voltage or if I'm in the wrong spot? The part name in the manual of both are IC-H. Thanks in advance. eric
  • Eric Boklep
    Eric Boklep Sep 23, 2010
    eagle338, Hey got an update for you... There is a 70" Mitsubishi TV in my living room that is alive. It's great that with your help I am now watching my TV again. I do still have a small convergence problem with a bowed screen top and bottom. Just need to have the time to get into that. And how do I mark this problem solved and give you thumbs up for your great advice and help? Thanks a million. Eric
  • Eric Boklep
    Eric Boklep Oct 03, 2010
    hey eagle338, my convergence is all haywire. is there a way to get it back to the factory settings.? the first time i tried to do the convergence the red is way off, the blue is ok, but the green lines are horrible (they are wavy on the vertical and in the corners they are bowed in, horizontally they are just bowed in the center). Is there a factory reset to this tv? i cant seem to find it anywhere? everytime i try to fix it it gets worse it seems. Please help. Thanks
  • Televison & ... Master
  • 17,130 Answers
For sure you are getting a higher voltage on to the section where the limit is 200 volts. So the Switch mode is irregular and not regulating the power output. Possible failure of the invertor oscillator IC., the power diode. in series.-possible AC factors coming in.
It is easier to trace back logically into the section of the positive voltage that the capacitor receives to identify.
When powering use a variable power supply to check before the full voltage is applied.
Posted on Aug 28, 2010
  • 2 more comments
  • Donald DCruz
    Donald DCruz Sep 02, 2010
    These are fusible resistors and they are of low value. Please do not attempt unless you are sure or you might end up with more damages. I insist that you must check the circuit in principle before it is switched on disconnect sections and proceed step by step.
    Please rate my comments.
  • Donald DCruz
    You cannot check an IC with the multimeter because of the compostion of the semiconductors within. Only if pins show a short like the voltage rail you can confirm .
    Most of the ICs mentioned are regulators and the pin voltage , the input to output values, current facotrs must be checked and I can go .
    You have still not rated me ....helpful
  • Donald DCruz
    I am off now but will check on your comments soon.
  • Donald DCruz
    The resistors are open but I think your regulators are also faulty..the STK's. Unless they work the voltage is not going to be regulated .Also with the damage there can be fault in the voltage/current path... a cascading efffect... Need to check...Thanks for the review.
  • 4,889 Answers
The buzzing noise usually comes from the deflection circuit. The first thing to check would be resistors to see if any of them are blown.
  • 14 more comments
  • eagle338
    eagle338 Aug 28, 2010
    Did u test the resistor to see if it's ok? Did you also test the other resistors in the circuit? Clearly caps going poof instantly is associated with blown resistors. So I told you that would be the first thing that I would check. I would also check to see if any voltAge regulator ics are fried.
  • Eric Boklep
    Ok, this is my first TV repair on my own and just cant afford to bring it in so please be easy on me. So I will test all those resistors. Also I did find some other bad solders on the convergence chips and touched those up. The board I am working on says power on 1 side, on that side it connects to the board on the right of it with the little wired clips. Is this actually where I should be testing other capacitors? I did trace it across to that board. Keep in mind also that I don't have any schematics or parts #'s to reference. How would I identify the voltage regulator ics? Thanks and sorry I'm such a dummy
  • eagle338
    Yes the power supply board is the source of the problem. You are working on the right board. Test the resistors and let me know. Make sure you set the multimeter to Ohm meter and set the range to auto(if its an auto-ranging meter). If the resistor is shorted it should read 1. or OL(over load). Once its done please update me on your findings. I will also look for a schematic in my collection. I have the schematics for most Mitsubishi sets.
  • Eric Boklep
    Eric Boklep Aug 30, 2010
    Sorry its taking so long. My multimeter found its final resting place. I'm borrowing a friends tomorrow and hopefully will get this accomplished so I can watch this giant again.
  • eagle338
    eagle338 Aug 30, 2010
    Yeah sure. No problem :)
  • eagle338
    eagle338 Sep 02, 2010
    Right you are. Its 5.6ohm indeed. Yes they have gone bad. Also test the ICs , transistors and diodes in the same circuit. If you dont know what the readings should be just get me the their number and i will see. Ex IC IC80C1
  • eagle338
    Yes I got your reply. But some of the comments may not be reaching me. Make sure you direct the comments to me.And yes the Ic numbers are correct. Check to see if any of them are shorted. From the numbers you have given me seems like some of them are voltage regulators. So test all of them Vcc of the IC With Respect to ground(You can use the common ground). If an IC is fried you will get a beep on your multimeter and a 1. in your reading.
  • eagle338
    Please address to whom you are addressing your comments coz I am getting confused. Anyways you should set the multimeter to volt meter. You can get the specs easily by googling for the datasheets of the ics. Ex: if ic no is ic8015 then search for datasheet ic8015. If you can't find any then let me know and I will get you the values. I hope you know terminologies like Vcc, gnd mean?
  • eagle338
    If memory serves right yours is a CRT projection tv. It does nor have a Colorwheel. And the diode is reading 490Volts? What is the setting? That sounds a bit too excessive. As for the transformer , now that you mention yes transformers can do that but not a very loud noise, the flyback transformer being an exception.
  • eagle338
    You did not me what unit it is? Volts? mV? Resistance? If you want to know whether its bad then this info is required. And CE CB are present in transistors . C-E means Collector-Emitter junction. CB means Collector-Base junction. As for testing a flyback the link below should be of immense help. However the flyback handles voltages of the range 25,000 to 30,000 volts. SO considering the fact that you are not well versed with electronics I am afraid it can hurt you. As my guru used to say "Your life and limb is worth much more than this". If you still want to go for it then click the link below
    http://www.repairfaq.org/sam/flytest.htm
  • eagle338
    And I thought we were talking about the samething since you posted this problem!
  • eagle338
    See one thing I am sure about is that its coming from the HV circuit. There are a lot of things that can go wrong. Sometimes you have to go component by component to identify the source of the problem. Since you have average skills the best bet for you would be to spot the source of the sound and take it from there. I will see if I have a service manual for this unit.
  • eagle338
    eagle338 Sep 03, 2010
    May be it will be easier if we can chat on messenger?
  • eagle338
    eagle338 Sep 08, 2010
    What kind of pointers? Please shoot what type of info you need and I will break it down into simple terms for you. As for the diodes in the last pages you will have whats known as electrical parts list. There the description for each part wil be given. Part number and the relevant technical specs etc.,
  • eagle338
    eagle338 Sep 09, 2010
    Cool. Good luck with the repair. And if you do get stuck somewhere , just whistle :)
  • eagle338
    eagle338 Sep 11, 2010
    Caps cannot cause the buzzing by themselves but they can overlioad the circuit and cause the transformers to do it. And yes the ICs you have mentioned can cause it. The STR ICs are the primary voltage regulators(block over voltage/over load). You can check out the datasheet below if you want to test if the ICs are bad.
    http://www.datasheetcatalog.org/datashee...
My vizio gets green lines across screen and looses sound after about an hour of operation sometimes with loud buzzing noise. Help!
Since the video and audio both are affected, we have to assume it is in the central processor next to the tuner, which separates these two. I suggest you note down the IC numbers, look for its datasheets and study what are the functions of each IC. Then look for any leaky/dry capacitors or dry solders in the board in the surrounding area of the IC. What I normally do is to replace all the electrolytic capacitors in the boards, if the TV is more than 5 years old or its use is so extensive. It is proved from my experience that the TV works like a new one for many more years. But you should do this only after ensuring that the TV is brought back to normal working condition. And, this requires a lot of patience and precision work, lest the boards should get spoiled.
Aug 23, 2012 | Vizio VP322 32 in. Plasma TV
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
JVC TV LCD Model LT-42PM30 intermittant buzzing noise
Most likely suspect is the power supply board---transformers on that board can and do vibrate hard enough to cause this.
At our shop we either locate the part creating the sound and treat it to hot blue to muffle and remove the noise or if confirmed to be on power board--REPLACE THAT BOARD.
Apr 29, 2012 | Televison & Video
My samsung 50 inch projection tv makes the noise like it always has to power up,but the green lamp button flashes. the tv also has been making a loud buzzing noise for a couple of months now that comes and...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem...
Aug 22, 2011 | Televison & Video
I have a Samsung 46 LCD, model LN46A550P3F, that about six months ago had the well known problem of cycling off and on, with the clicking noise, and making occasional LOUD static noises with a distorted...
Power supply board u fixed before was good,but the tv main Tuner signal board it was working on it last leg.Distorted picture screen loud static noises are the indications of the tv main Tuner signal board are not regulating signals of all of those ICS output on the tv main Tuner signal board it is dying and now it is dead.Don't change the T-CON bord it is good.Tries Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement.
Aug 01, 2011 | Samsung LN46A650 46 in. LCD HDTV
Tv keeps turnig off
You have the V26 chassis with it's notorious problems caused from leaky capacitors. The fix for this is a multitude of capacitors replaced on the DM board, FMT board and the power supply. The right thing to do is to call Mits consumer relations @ 1-800-332-2119 with model, serial and date of purchase and they should be willing to make a concession for discount on a new Mits DLP. That's your best bet. This TV will continue to haunt you otherwise.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
We have a Polaroid 37" HD tv that has a loud
You have weak capacitors in the power supply and the signal board. I have not repaired this particular unit, but have experienced this with other Polaroid TVs. You will need a TV tech to replace those capacitors. It is a very time consuming task and requires patience and much care to remove the capacitors. Tell a tech that they must be very careful when they remove a cap in the signal board, as they can peel off a pcb trace. In most cases they replace the signal board, but the capacitors can be replaced! Thanks for asking and show a few hands of support!
Jan 03, 2011 | Polaroid FLX-374 37 in. LCD TV
Blow capacitor 820uF 25v? where can i buy them? or how to replace them with other capacitor?
You can buy that to an electronics store near your area. Replace that with same value or if you have higher than 25 volts use it provided that it is same as 820 microfarad.
Jul 09, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
