Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Convergance converance is totally out of allignment and will be corrected
  • Samsung Master
  • 8,617 Answers
Change both convergence Ics. You can get new replacements at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 18, 2008
All of a sudden the convergence is out of allignment and I am not able to correct it following the owner's guide instructions
looseing convergence all of sudden is definatly of component failure... with convergence there a good chance the chips that control convergence have failed. ... these chips called stks. do you have any convergence at all. when you tried to align did the crosshairs move at all left right blue red? if you have any control it might be what is called a resistor ...let me know and i will try to help
you might need a technician to help this is a involved repair
Oct 16, 2010 | Mitsubishi WS-55513 55" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
Color allignment on a Mitsubishi WT-42311 42in Rear Projection
You will need to replace the two stk-392-110 convergence chips this model uses. This can be a do it your self job if you have some skills.
This model has a light box which contains 98% of the set's inner parts. With it removed the chips will be easy to locate.
Total parts cost on EBAY should be under thirty dollars and repair should take about a hour or so.
YOU will need to be able to solder as the chips have 18 pins each.
If you think you can do it I can tell you how to get the light box out and proceed with the repair; this model has very few problems and a good picture.
You will also need to have the Mitsubishi remote to correctly adjust after the fix.
Let me know what you want to do--I am here to help.
SD TECH
May 07, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Convergance wont allign on 50" panasonic
Must replaced the 2 convergence ICS,and all it resistors.Must know how to solders.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts,and lobors.
Jan 16, 2010 | Philips 46PP9302 46" Rear Projection...
Projector allignment
THIS IS A DIGITAL CONVERGENCE TV. FIRST IF YOU CANT ADJUST YOUR CROSS IN CENTER YOU PROBABLY HAVE A DEFECTIVE CONVERGENCE IC
IF YOU CAN THEN THE SERVICE MENU PROCEDURE TO CORRECT GEOMETRY IS COMPLICATED AND TIME CONSUMING. YOU WILL ALSO NEED THE ORIGINAL REMOTE AND THE SECRET ACCESS CODE FOR THAT SET
Dec 20, 2009 | Mitsubishi WS-55807 TV
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
Nov 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
Blue converence was intermitten now out on sides
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Mar 11, 2009 | Sony KP-61V45 61" Rear Projection...
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
Replacement or instruction needed to fix T.V. Convergence
The conversion amp ICs. Let me know if you need more info.
Mar 04, 2008 | Televison & Video
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
