Question about Kenwood KAC-X501F Car Audio Amplifier
I took my stereo out and the battert cable thouch a sertent wire and sparked. i put my stereo back in place turned my car on and now it wont turn green or red and now spark from tne batt to amp cable
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Electric current and voltage required for a car amplifier is the voltage of B + and ACC, commonly called the primary voltage with a mark of B + = 12Volt-13, 8 Volt and ACC from the Iginition switch, the same voltage = 12 Volt. so make sure both are available in the car audio amps. Possible loose or broken wire as you remove it, or from broken fuse, check the fuse box panel in the car for the ACC (Accecories) fuse, if broken replace with a new one (with the same Ampere)
Posted on Aug 28, 2010
While trying to install an aftermarket radio the wires curcuited or blew now my dash lights and stock stereo wont work
you might have blown out all your electrical under your dashboard you might want to check your fuses in your car.
Mar 16, 2013 | Cars & Trucks
I took out the stereo of my 2000 outback and put it back all wires plugged in and it wont turn on any ideas of what might be the issue?
check your fuse box and see if your radio fuse is blown if it isnt you should try connecting the yellow and red wires from the radio and the harness all together and see if it comes on. if it does theres a problem with the main power supply (red wire from the harness). quick fix : run a new wire from the red on your stereo to the fuse panel and connect it to the radio fuse.
Mar 04, 2013 | 2000 Subaru Outback
I think I blew a fuse in my 2000 Toyota Corolla
find the fuse that says radio and replace it
Dec 03, 2012 | 2000 Toyota Corolla
Why wont my stereo wont turn on
make sure you have a good ground and 12 volts on the power wire.the problem is in the way you are wiring it if the unit works when hooked to a battery.
Jun 14, 2012 | Cars & Trucks
How to remove and put the a new radio in a toyota highlander 2002
  • Disconnect the negative battery cable and ensure it doesn't contact any metal parts. Place the transmission into the "Drive" position and set the parking brake.
  • 2
    Remove the trim from around the stereo by prying at one of the bottom corners with your fingers. Apply pressure until the clips disengage and work your way up the trim. Once the trim is free from the dash set it safely aside.
  • 3
    Locate and remove the six 10mm bolts that hold the stereo in place. Pull the head unit out of the Toyota highlander dash and disconnect the wires from the back of the radio.
  • 4
    Connect the wiring harness adaptor to the original harness. Mount the new stereo into the Toyota radio mounting kit and secure it by following the manufacturer's instructions. Plug the wiring harness adaptor and antenna wire into the back of the new stereo.
  • 5
    Slide the entire stereo assembly into the dash and reconnect the battery cable. Turn the radio on and verify the speakers and controls are working on the new stereo. Secure the stereo in the dash with the six 10mm bolts and replace the trim ring around the radio.
  • Dec 07, 2010 | 2003 Toyota Highlander
    I took my 92 jeep wrangler's distributor cap off, put it ack on, and put all the wires back on. Now it wont start, it wont even turn over.
    If the engine won't even turn over, it has nothing to do with the cap or wires. Perhaps you accidentally damaged or disconnected the battery cable to the ground, or one of the wires going to the starter? These are located in the same general area.
    Dec 01, 2010 | 1992 Jeep Wrangler
    Dome lights wont shut off stereo turns on but no sound
    remove seats and pull carpet. now see which wires they melted with that torch. Tape them up so they aren't shorting out any more as best you can.
    Apr 07, 2009 | 1998 Jeep Grand Cherokee
    Carolla stereo wont turn on..
    Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
    Cheers.
    Nov 09, 2008 | 2004 Toyota Corolla
    Connecting remote cable to other port from the car stereo
    You can tap the amplifier's remote wire into the accessory power lead at the back of the head unit. On most head units this is a red wire. Doing this will make your amplifier turn on and off with the key switch, rather than the deck power.
    Jul 01, 2007 | Sherwood XCM-6870R CD Changer
    Kenwood KAC-X501F Car Audio Amplifier Logo
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
