Question about Frigidaire FRS23R4A Side by Side Refrigerator
FRS23R4A Side by side
Our side by side freezer has water that gathers at the bottom under the pull out basket. We have see water dripping in the back of the freezer around a drain that is in the back wall of the freezer. Is it possible that this drain is plugged causing it to drain under the basket and freeze? If so how do you unplug this drain.
Will ice maker work without filter
Posted on Aug 04, 2008
  • 828 Answers
The answer to your question is yes. You can access the drain from the back of the freezer. In most cases there is a seal loop that sometimes plugs up. You will see the hose going into the drain pan under the unit. I use a piece of speedometer cable as a mini rotorooter.
Posted on May 07, 2008
Water drips form on a basket sort of thing toward the back of the refrigerator. It drips so badly that I have to use a water vacuum to remove it. What is causing it? There doesn't seem to be a drip...
Most likely your defrost drain hole is plugged and needs to be cleared out, if you remove the back panel of the freezer you can poor hot water and then soak it up until the hole is clear. It takes many tries, like about 20 with very hot water. Start by disconnecting the power, removing the 2 screws on the bottom of the freezer, pull up the bottom and remove, It may be stuck do to the ice, Remove the 2 screws on the back wall and pull it toward you disconnecting any wires. Under the aluminum radiator looking thing and under the ice there is a drain hole that needs clearing..
May 17, 2011 | Hotpoint Refrigerators
I have a jenn air side by side and water seems to be leaking near the front left corner area at random times and when it does leak it is a slow drip.... thoughts?
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Oct 31, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer side has a drip inside on back panel that
if you can find the a hole the opening is size of a hose, that is where that water should go, see if there is any small object blocking the way out or the hose maybe clogged, just clean it with hot water, turn it off first
Nov 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is leaking out the bottom of door
clogged defrost drain. remove ice from bottom of freezer and take very hot water and work back and forth with a turkey basteruntil water drains. blow out with hose.
Jul 25, 2009 | Frigidaire FRS23R4A Side by Side...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Aug 17, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer compartment leaking water and icing up inside
Solution #3 fixed it.
Pulled everything out of the freezer, found where the drain was, it was blocked with ice, hot water and then a flexible straw, the kind that comes from an ammusment park kids container, shoved it down the opening after the hot water and it cleared whatever was blocking the drain.
Thank you very much - Mark
sdsu1985@yahoo.com
Sep 25, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
112 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
