Question about Jet 3 Ultra Power Chair
What size is the battery compartment for the Pride Jet 3? I am trying to order batteries on-line and don't want to take the power chair apart to make sure the terminals and size are correct . The Pride company doesn't know or won't tell me the compartment size. I don't want to return batteries if they will not fit correctly. Help!
  • 692 Answers
Raine you need to purchase two U1 batteries for your Jet 3. I would check locally with a battery outlet store first because your cost can be less that $200.00 for both batteries this way. If the on-line comany wants more than $200.00 for the 2 batteries plus shipping I would look hard in the local area. Hope this helps
Posted on Sep 01, 2010
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
What is the fix for Pride power chair code 3101 bridge voltage fault?
The fix for this fault is to replace the chip in the VSI controller. This happens when you consistently drive the power chair with weak or low voltage batteries.
Sep 02, 2014 | Pride Mobility Products New Pride Mobility...
Batteries charge but they drain quickly
If your batteries are over 3-years old or are a poor quality (Werker, ISO, Long, no-name, etc) then you need to replace the batteries. Many independent battery dealers can load test and test for internal resistance. Both tests will determine if there is a battery issue.
It is best to always replace these gel or sealed lead acid (SLA) batteries as a pair.
The Pride Mobility Jet 3 typically takes two each size U1 batteries. i.e.: GPC1234 or UB12350.
Apr 13, 2014 | Jet 3 Ultra Power Chair
Go Chair goes slow
check the breaks are not sticking on.
slacken off or remove to try if this is the fault
Jun 02, 2013 | Pride Mobility Pride Go-chair Travel Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
Pride JET 3 Ultra power wheelchair. Problem: Batteries drain very fast after recommended charge. Things I have done: Replaced both batteries- twice; Replace On-board charger. Both items brand new. ...
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jun 10, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
64 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
