Question about Canon PowerShot SD850 IS Digital Camera
I have sd850 is digital camera , why when i take a picture at night even i use flash the picture comes out to dark . do i need to use the flash or not. i always put in automatic . if i don't want to use flash what should i do
    President:
  • 1,509 Answers
Go to your ISO settings and set it higher. take several pictures till you seee wnat works. the flash is only good for about 10 fet if it's truly dark. Turn it up all the way and if it's too bright turn it back till you find what you want. the lower the better untill it's too dark. Try pushing the pictures with your computer and as long as your not a witness for court cases pushing the pichures with your computer can give you some great pictures as long as the cameria got the picture OK to beginwith as the lower ISO settings will give you more to work with as the ISO goes up the quality goes down and as you push with the computer the quality goes down but if the orginanal has enogh ( Juice ) in it and you computer prgram is a good one then you can make good Processed pictures and you may be pushing the limits of the camera. Maybe next time shell out for a better camera that has more than 10 Megapixals and you'll start seeing into the dark, 20 megapixals really do well but how deep are your pockets? Pup a big flood light on the job and use the flash with the best batteries that you can find and maybe you can get what your looking for. I'm a pro but some low light pictures using a tripod and a remote shutter( to remove all shake) sometimes can get the camera to step up and get the best picture it can take. Take lots of pictures and use brade name chips as some of the noname chips can do a low light picture bad I've thrown away all the cheapie chips I had and I only use the Hi dollar ones, and I'm good to go.
Posted on Aug 28, 2010
SOURCE:
Flash/dark pictures
If this camera is new, take it back.
Apr 28, 2010 | Kodak EasyShare C613 Digital Camera
I have a canon powershot SD850. I'm having
Turn the dial to SCN, then use the right/left to select night scene.
Jan 24, 2010 | Canon Cameras
Pictures taken at night usually come out dark
Please readjust the ISO.
In order to find a pattern please experiment: For example: Try Different SCN (If you're experiencing this problem with your night pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
Dec 06, 2009 | Kodak EasyShare DX6490 Digital Camera
I have a problem with my canon sd850 is. It can
You should be able to set the flash to off, auto, auto with redeye, slow-shutter sync, and forced flash on. The last two should give you the results you're looking for. If these aren't available in manual mode, get out of manual mode.
Nov 22, 2009 | Cameras
All the night time pictures are black.
number 1: do you have the flash on? if you don't that's what happens, the snapshots taken at night will be dark.
number 2: even with the flash on, the background will most likely be dark being that the light from the flash isn't going to travel far enough to for you to see every detail. also the closest thing to the camera or the subject will be brighter of course because the light hits it first.
and if that's still not it then it's probably a defect in the camera or maybe a lens error. it could just be a sorry brand name and you need to get a better camera. when all else fails, take it to be repaired.
Jul 14, 2009 | Canon PowerShot SD1100 IS Digital Camera
Pictures to dark at night
no there isn,t.but these cameras do not have enough flash to take great pictures at night,for one you cant be to far away,two you have to have a subject in range of the flash,other wise all you get is darkness.but at the most 10ft is the farthest you can go and still get a great shot at dark.also use auto mode when taking pictures,because it adjusts to light-dark etc.i know this because i have the same camera and its awesome,plus im a photo technician and ran a photo lab for 3years selling digital cameras. good luck,hope i helped
Mar 28, 2009 | Samsung S860 Digital Camera
Picture is dark when taking it at night.
Hello did you try brightening the frame rate of the camera?? and the quality of the picture?? That usualy would help..
Jan 14, 2009 | Canon PowerShot SD1100 IS Digital Camera
Flash wont come on
If your flash is failing, it will require service by Canon.
Dec 24, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Cannot take pictures
cannot take a picture the lcd is on blank screen
Jul 14, 2007 | Kodak EasyShare CX4310 Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
