Regulator I too am having the same problem with the gas barely coming out, stays at 250 no matter what. Where can I purchase a regulator for the Medallion by Vermont Castings? Thank you in advance.
  • 1,420 Answers
If this heater is hooked up to a propane tank with an "OPD" valve, with the heater on; turn the gas off at the bottle. Allow it to set 30 seconds or so. Now turn off the heater. Slowly and I mean SLOWLY, turn on the tank. Now light the heater.
Posted on May 16, 2008
Why is it no matter which way I adjust the oven's spud orifice, the burner flame stays large, yellow and sooty even after adjusting the air shutter?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
I smell gas, but not all the time. It is most when my car idles for a minute. I have not noticed a gas leak.
this issue may be caused by a faulty fuel pressure regulator... next time you smell gas, pop the hood and look at the lines running to your regulator and you may notice gas leaking on the metal line running from your tank to the regulator. this would indicate that you need to replace the regulator; should cost about $250-$300
Jan 01, 2011 | 2005 Chevrolet Monte Carlo
I have a 1993 buick century custom. im currently getting 198miles to the tank. at normal idle the car sounds like its being choked of air and trying to stay alive. always starts right up, never stalled and...
recommend you pull the vacuum hose off the fuel pressure regulator at the end of the fuel rail and check for gas in the line. You can plug the hose with a golf tee and start the car, then see if any gas comes out of the vacuum port of the regulator. This would indicate the regulator diaphram has failed and is causing the engine to run rich. Replace the regulator if it leaks gas out the vacuum port. The regulator looks like the below picture.
Nov 02, 2010 | 1993 Buick Century
We have a barbeques galore turbo stainless stell 3 burner grill, We can't get it to heat evenly and now it barely heats at all.
Either the burners are dirty and the holes for the gas to come out are plugged or the gas pressure regulator is bad.
Check the burners and make sure they are clean and if they are then check the regulator.
heatman101
Aug 19, 2010 | Barbeques Galore Turbo Classic 3-Burner...
My 7.3 L diesel ford f-250 shows the battery light (check charge system) on in the dash. I tried to drive it and the voltage gauge started dropping into the 10-11 v range. I replaced the alternator...
You must have an older vehicle,but I am pretty sure the 7.3 was put out after the voltage regulator was put in the alternator.What you are describing is a voltage regulator on the the firewall.If this is so,replace the voltage regulator on the firewall,with a new one.This will be the problem most likely.The voltage regulator on the firewall should be kind of flat,almost square,and a wide plug,goes all the way across the voltage regulator.If You don`t have external regulator,then it is built in the alternator,and the alternator you purchased is bad.Be sure the wires on the back of the alternator are not broken anywhere.The big post ,largest wire,on the back of the alternator is the out put wire.It should go to the battery.If it does not have 13.65 to 14.25 volts on the back of the alternator,and at the battery positive post.Like I said,I believe the voltage regulator is on the firewall,if it looks like I described,then it is a regulator,replace this part(voltage regulator)and it will solve your problem.I hope this was some help,please let us know,thank you.
Oct 15, 2009 | Ford F-250 Cars & Trucks
Regulator Repeatedly Reduces The Gas Flow
The new regulators will automatically shut down or reduce flow if the it senses that the flow is too high (as in a line leak or break). It can also be folled if you open the valve too quickly. There is a special plastic plug that can reset a tripped valve in the new tanks. (Mosquito Magnet supplies one with their product).
The other thing is that there is a recall going on at Char Broil of defective thermometers that are reading too low.
Sep 28, 2009 | Char-Broil Commercial Stainless Steel...
Wont come on
low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Aug 04, 2008 | Vulcan EF3 Deep Fryer
Medallion Vermont Casting model CF9080
sounds like the regulator. there isn't much of anything left to go wrong! the gas comes out of a very small orifice in the burner tube and mixes with atmospheric air before being burned at the jet.
Feb 02, 2008 | Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
