Question about CIBA Vision Gigaware 2.0MP Webcam
The drivers for my webcam is missing (it´s a "Focus")
  • 10,421 Answers
Out of focus
reinstall the software of your cam
Jan 26, 2014 | Digital Innovations 4310100 ChatCam Webcam
I have a Gigaware 2.0 Mega Pixel Auto Focus Lens. I usually turn the auto focus off, and it works fine. But now, I turned off the auto focus, and it's still blurry. I already tried re-installing software...
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 29, 2013 | Radio Shack VGA PC Camera Webcam
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
I can´t find the driver
http://support.radioshack.com/soft.htm
Jan 05, 2011 | Radio Shack VGA PC Camera Webcam
My webcam of the acer aspire 5738g don´t work
To download the Acer aspire 5738g webcam driver --please click here
---and here
Dec 10, 2010 | Acer Crystal Eye webcam
I have installed the webcam and my image is blurry
Adjust the Focus: The Logitech Webcam C200 has a manual focus. It may need to be adjusted upon initial use, and from time to time, as bumping and moving the webcam may accidentally knock it out of focus.
1. Locate the knob that surrounds the camera lens (shown below).
c200-cs1.jpg 2. Twist the knob clockwise or counterclockwise until the camera comes into focus.
Improve the image Quality:
To improve the image quality or avoid any type of blurriness from your camera please verify that the following:
  • You have good lighting in the area or room where you are using your C200.
  • Your computer has at least an Intel Pentium 4 (2.4 Ghz) processor and a minimum of 256MB RAM.
Nov 25, 2010 | Logitech WEBCAM C200
Can´t find the driver for
Zoom ZoomCam III -USB 1598 Personal Web Camera Driver
Nov 12, 2010 | ZoomCam III -USB 1598 Webcam
The cam seems out of focus What adjustments can be made
Either the webcam has a physical focus ring somewhere in front of the lens, or it has to be a auto-focus setting in the webcam software properties. Check the driver details.
Jan 05, 2010 | A4tech PK-635 Webcam
How to fix my web cam
hi..
The very first step is of course to check your webcam connection.Most webcams use the USB port to connect to the PC, so check if yourUSB cable is properly plugged. For build-in webcams this steps does ofcourse not apply. Many new laptops have a build-in webcam. Also tryconnecting your webcam directly to your PC instead of through a USB hub(if you are using one).
It might be that the hardware is recognized as a camera, but theright drivers are not installed. The yellow explanation mark willindicate a problem.
In case no driver for the webcam can be found, you can try a third party driver scanning program that scans your PC for installed hardware and allows you to install missing drivers.
After uninstalling the software, restart your PC and then reinstallthe webcam software. In most cases this will solve the problems.Depending on the software, you might need to unplug your webcam duringthe software installation.
If the drivers and webcam software are correctly installed, and youstill cannot see any video, there can be a problem with the programsettings. Most chat and meeting software have a configuration option toselect the video source for the webcam feature. If you have multipledevices that qualify for video, you might need to select your webcamdevice as the source for the webcam feature in that program.
Some webcams and programs require additional software, although thatshould be installed with the webcam if things are right. But is doesnot harm to check if your Java, Flash and Quicktime software are installed and up to date.
Lastly, if your webcam’s image is not sharp, check to see if it hasa focus ring. A blurry image can sometimes simply mean the webcam isnot in focus. Adjusting the focus through the ring can solve thatproblem....
thank u
rate me!!!
Jul 14, 2009 | Computers & Internet
Lost driver cd
www.driverguide.com would have drivers also try www.download.com if all else fails. Thanks
Jun 09, 2009 | Computers & Internet
CIBA Vision Gigaware 2.0MP Webcam Logo
Top CIBA Vision Computers & Internet Experts
David Payne
David Payne
Are you a CIBA Vision Computer and Internet Expert? Answer questions, earn points and help others
