Question about Garden
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
    New Friend:
  • 6 Answers
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Posted on Apr 03, 2014
  • ray gallant Nov 14, 2015
    Gerard some guy wants to know if you will do it for him. check posts his name is Wallace Franklin
Sorry, the batteries on this light are permanently installed and are not replaceable.
You charge it like a cell phone with a wall charger.
When it no longer takes a charge, throw it away. Not a real great product.
Regards,
The Electron Guru
Posted on Aug 19, 2011
  • 2 more comments
  • Vincent Harris
    Vincent Harris Jan 14, 2014
    Thats not true. You can actually very easily remove the battery. However locating a replacement battery is not as easy as I am running into that myself.
  • Gerard Jeronowitz
    Gerard Jeronowitz Apr 03, 2014
    I know this thread is old, but I just had to change the battery pack in mine so here's what I did:
  • Courtney Thompson
    Courtney Thompson Sep 25, 2017
    Does anyone know what to do if you've successfully replaced the battery pack but it still won't take a charge?
  • Carolyn Foley
    Carolyn Foley Jan 29, 2018
    just took ours apart today...skip all the solder stuff and buying the clip on battery unit from batteries plus
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
Nov 28, 2015 | Stanley Camping, Backpacking & Hiking
My stanley 28064 wireless remote system
need instructions forstanley28064 to replace battery
Mar 28, 2013 | Stanley 31164 Indoor Wireless Remote...
How do I know if my Stanley Bar-Flex BF0109 work light is fully recharged?
Gerard, PLEASE contact me at (941) 391-5152 or WFBanach@aol.com so I can hire you to replace the batteries in my Stanley barflex bf0109 light like you did above with vastly more run time mAh. I need someone to do it for me. I'm disabled. I just joined fixya.
Thanks,
Wallace Franklin Banach...
Aug 27, 2011 | Stanley Garden
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
I need to jump start my car but lost my manual. Are there instructions online somewhere?
If you need to jump the car regularly ... it is time for a new battery. I see you have a jumper device, attach the red or + lead from your power station to the POS or + or Red terminal on the battery. Put the black or - from the power station to the Black or - post of the battery. Start the car.
Thanks for your question @ FixYa.com
Feb 17, 2011 | Stanley Proto Stanley DPS109 Digital...
I lost instructions for an outdoor 6 outlet timer made by stanley.
To identify your timer for sure, look at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#31217
If this is not your timer, then add a comment
Stanley timer information I've see on seller's websites matches the Westinghouse 28455 manual:
http://waterheatertimer.org/pdf/Westinghouse-outdoor-28455_TimerManual.pdf
If this manual does not match your timer, then add a comment and describe what you see on the timer display, and I might be able to help further.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price if they have instructions.
Dec 24, 2010 | Stanley Proto Stanley 31217 Digital...
Need a replacement charger & instruction sheetfor the bar flex light bf0109
I need a replacement cord to recharge my Stanley Bar Flex, Model #BF0109S, 6Vote DC-600mA. Is this something I can purchase from you?
I can be reached at 207-395-4721 or you can email me at: jawperk@aol.com
Thank you for your prompt attention.
Jane W Perkins
East Winthrop, ME 04343-0373
Dec 21, 2010 | Stanley Camping, Backpacking & Hiking
Have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Apr 05, 2009 | Chamberlain 950CB Remote Control
Garden Logo
2,476 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
