Question about Krups FBC2 1600 Watts Toaster Oven with Convection Cooking
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just haven't gotten the time to dismantle the unit to see what is up and also we use the oven all the time. Thanks!
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Posted on Jun 04, 2012
  • 4 more comments
  • Large Marge Dec 09, 2012
    Where did you get the part? Thanks in advance.
    Where did you get the part? Can you please provide a link? Thanks in advance.
    Sorry for that duplicate comment, not intended. I just found the part here:http://www.appliancefactoryparts.com/sea...
    Actually I found it at Krups for 3 bucks less. Part number is SS-185306.
  • Mark Gamba
    Mark Gamba Jul 03, 2014
    Unfortunately I did not come across this until I had already removed the four front screws that hold the keypad, door and that pesky little piece of plastic at the hinge. How did you manage to hold that in place to get the screw back in?
  • Jimnanna
    Jimnanna Dec 20, 2014
    These instructions are excellent. My husband and I repaired the job in about an hour which included cleaning the toaster before dissemble. It was a bit hard to get the metal case off and we had to do all the steps including the last steps where you remove 3 of 4 black inside screws. The color of our toaster hardware was a little different but the instructions were clear enough to know no additional adjustments were needed. We recommend going straight through to removing those last 3 screws. We are not sure you could remove the housing out without doing that. It was a bit hard putting the shell back over and took some maneuvering and some temporary screws in some places. It is handy having an extra person to do this job. We actually did not buy a new spring. Instead my husband lengthened the spring with some pliers and then created a loop on the end with different pair of pliers. We could tell from the replacement part picture what we needed for that loop. We never found the broken detached piece that kept the door hinge working properly. Our door is a little difference not using an exact replacement part but we are optimistic our solution should work for some time. Thank you for very much to the gentleman who wrote such thorough directions to this problems. Krupps was of no help whatsoever. They just want to sell new toasters.
  • 17,130 Answers
I assume that the glass hinge has come off or is broken.
For both the cases you can either remove off the old glass door and fix a new one with the therrmal properties.
the next option is to salvage on similar type from a service shop.
The other option is to stick along with a glass fixing adhesive a small rectangular glass to wedge into exactly over the broken glass and have the hinge centralised to make sure the alignment is correct to close the door properly.
If only the hinge has come off then use an extender to hinge to glue on with a glass fixing adhesive.
Posted on Aug 28, 2010
  • 2 more comments
  • jwroenigk
    jwroenigk Jan 08, 2012
    I have the same issue with the door hinge; not the glass part falling out but rather the hinge mechanism not keeping the door shut tight. Any body figure out how to replace the hinge mechanism?
  • gjgaryjones0
    gjgaryjones0 Jun 04, 2012
  • Paul G. Jan 02, 2013
    The description is helpful. However, can anyone look at their correctly assembled toaster how and describe how to correctly re-position the door hinge on the left side? Mine accidentally came off the spring and fell into the space between the metal exterior metal cover and the inner oven panel. I was able to remove it, but I can't figure out how to put it back into place, as there are four possible positions for this odd-shaped metal hinge. Specifically, each side has a small hole, and one is larger than the other. The larger hole looks like it's at the top of a bird's beak, whereas the smaller one is at the center of a small circle at the other end. I need to know which side can be seen emerging from the slot at the left, as that's the one intended for inserting the glass door's metal catch-hinge. The other side is for the spring. If the part that protrudes from the slot is the small, circular end, does it lean toward the left or toward the right? Mine looks bent, but maybe it's supposed to be that way so it does't keep falling back into the slot. Thanks for your help.
  • warcraft demonhunter Apr 07, 2013
    As gjgary noted, if the bottom screw that holds the black plastic piece in place come off make sure you screw it back in place. Mine came loose when I put my oven back together after installing new bottome elements and the door didnt open and close properly. I had to remeove the top/side panel again and install the screw at the bottom left opening of the doorway to the black plastic piece.
I need a Manual for a Krups Counter Convection Oven
Krups has one manual for the FBC2, FBC3 and FBC4 models. Start here: http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm and use the drop-down menu on the left to select Toaster Ovens. Then select the FBC2. Click on the green and black icon to download the manual. The direct link to the manual is http://www.krups.com/NR/rdonlyres/5605B757-078E-4DF1-9DED-A884209066C8/4351/TOASTOVENFBC234_usa.pdf . The manual is also available here: http://static.highspeedbackbone.net/pdf/TOASTOVENFBC234_engusa.pdf . You can also get this manual from the Krups FBC2 product page: http://www.krups.com/All+Products/Toaster+Ovens/Products/FBC2/FBC2.htm . Click on the Instructions link.
I hope this helps.
Jul 27, 2016 | Krups FBC4 1600 Watts Toaster Oven with...
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
How do we change the heating element. It was hit and broke but not in half so we need to remove it and add a new one.
I ordered bulbs online at http://www.smallappliance.com/ They come in a set of 6, you can't order less than that, I looked all over the place. Here is the part number: Krups SS-185303 Heating Element. You might want to find them on Amazon.com because by the time you order them from the above website, with shipping, it will come to more than you will pay total on Amazon and it's coming from the same place. Just in case Amazon doesn't have them in stock (you never know) I wanted to give you the source for the bulbs.
  1. Unplug unit and remove all trays and racks and crumb tray. (I took this time to do some much needed deep cleaning too.)
  2. First you have to remove the old bulb. I tried it the hard way by trying to pull it out - it's connected with screws on the left and right to the connector wires.
  3. I placed the oven on a big light colored towel and had a cup ready to place all my screws in. I also took pictures of it before I started taking it apart so I had something to reference when putting back together. I used a small sharp phillips head screw driver, DW40, household oil, a set of leather household gloves and patience.
  4. I first removed the cover of the whole oven by starting with the bottom legs (there's a screw under the rubber foot), the bottom, back and then removed screws on the face/door. Becareful of the door hinge. You might want to use some household oil or DW40 before you start to attempt this. My oven is 6 years old and we've used it everyday. There was some accumulated stuff around the screws.
  5. Carefully remove cover of oven and door/face. There's going to be a thick wire that will connect the interface circuit board to the internal boards so again, becareful when removing the face of the oven. The glass door may pop out of the hinge so, again, becareful.
  6. Make sure and observe how the door hinge and spring are placed and take a picture as you're going to have to put it back together.
  7. When I got to the connector of the bulbs I had to use, very carefully, some more household oil on the screw.l I held the ceramic socket with my leather utility gloves on and gently applied pressure to get the screw loose on both sides.
  8. Carefully place new bulb in hole/holders and gently screw the wires back on, start with the right side (facing the oven).
  9. Reassemble the door hinge if you took it off. and place the face on just for position.
  10. Attach the outer cover, back first and then bottom.
  11. Attach face and make sure hinge is working properly and you've tucked that wire back in.
  12. Attach legs.
  13. Remove anything else plugged into socket you use for the oven (just in case it blows the socket which has happened with some DIY repair in our house). Plug in oven and test it out.
  14. I hope this has helped you. If not, find some coupons for Bed Bath and Beyond and purchase a new one and sell your extra bulbs on ebay or craigslist. Good luck!
Jul 10, 2011 | Krups FBC2 1600 Watts Toaster Oven with...
I have a fbc2 krups convection oven and the handle is broken. is there a replacement for this?
Molly, there appears to be some replacement parts available:
this is a link for the oven door and handle, which appear to come together: http://www.smallappliance.com/product.asp?pid=2478&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category this site is referenced as authorized by Krups, but Krups did not show this replacement part in their online store.
this is a link for the tray handle: http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+SS%2D185298&MENU=parts&SELECT=toasterovens&SKW=PARTFBC2 for 1.99 from Krups, and http://www.smallappliance.com/product.asp?pid=2479&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category for 8.99 from smallappliance.com, referred by Krups.
Hope this is helpful.
Dec 22, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
My Krups FBC 1 toaster oven has a broken spring for the glass door.
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
Dec 19, 2010 | Krups FBC1 1600 Watts Toaster Oven with...
I have a brand new Euro Pro Toaster Oven, Model # TO176. After a week of use a pin or similar piece fell out of the door hinge, and the door keeps falling out on the right side. The left side is still in...
My mother had/has the exact problem right down to the teapot. I am in the process of fixing it, but don't have time to post solution right now. I will post later today. I should probably post a video as it is not real simple.
Oct 26, 2010 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Krups FBC2 1600 Watts Toaster Oven with Convection Cooking Logo
2,827 people viewed this question
Top Krups Toaster Ovens Experts
Tom Chichester
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
