Question about Konica Minolta Magicolor 2530 DL Laser Printer
1st of 3 pins seems to be loose
Hi, my printer is saying that all 4 cartridges are not installed even though they are. Upon working on your solution, I discovered that the first of the three pins is loose and seems to be dislodged. How do I remove the white carrier to replace the pin? Or what is it called (and where do I shop) to replace this white carrier?
  • noelfeliz Jun 04, 2008
    This piece is called a "crum reader", which Konica Minolta quickly replaced as it is under warranty. The labor, however, is not, and your post saved me! Thanks!
    Champion:
  • 214 Answers
Its a cartridge chip reader, you can remove the plastic peace with 3 pins, first remove wire, then under both sides of that plastic peace is a small knobs you can push a little and just remove it. if these pins look OK, then use pressure air to clean these pins and the plastic.
Posted on May 27, 2008
My Brother Printer MFC-J430W always says "install Magenta Ink" even though it is already installed
reset the engine to the factory. and clean the cupper pins that are on back of cartridge and on the carriage.
Oct 09, 2016 | Brother MFC-J430W Inkjet All-in-One...
Bought and installed a brand new color inkjet cartridge but monitor still say's it is out of ink. I ran the "maintanence" and the "cleanhead" command's but it still say's...
1.
1. ALWAYS READ THE MANUAL ON HOW TO INSTALL IT. I DO NOT CARE HOW SMART YOU ARE, ONE SMALL ERROR WILL CAUSE FRUSTRATION AND POSSIBLY MORE WORK.
2. DID YOU LOOK AT THE LIGHTS TO ALERT YOU TO THE PROBLEM? MORE HELP IS IN TROUBLESHOOTING GUIDE.
3. ARE YOU USING DELL CARTRIDGES OR GENERIC?
4. A BRAND NEW "ALL-IN-ONE" SHOULD NOT NEED A CLEANING. IF YOU DID A DEEP CLEANING IT SUCKS THE INK RIGHT UP.
5. YOU CAN ALWAYS CALL DELL FOR FREE.
Sep 21, 2011 | Dell 968 All-In-One Printer
I installed a new Ink Cartridges in My Canon Multipass MP390 color inkjet printer and now it won't print, Though the machine is on the compartment that carrys the ink cartridges wont even move as it its...
Hi Good day!! well i know that you can fix it. 1st off all is there any message error in your printer? if none then we will try to troubleshoot it in the printer spooler. Printer spooler is located in the services. please try the following.
1. turn off in a few seconds and then turn it on see if the ink cartridge is moving.
2. Click "Start
3. Click "Setting
4. Click "Control Panel"
5 Click "Administrative tools
6. Click "Services you should be on the services box now.
7. in the service box find "Printer Spooler
8. Click "Printer Spooler" all you need to do is to restart the printer spooler Stop and then START it again.
Try to print now hope your ink cartridge move..
ReGARDs
JR
Oct 07, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Says that I need ink even though I just replaced it
Replace all the ink cartridges??????? If this is HP's idea of how to sell more ink my printer will be floating down the Ohio River very shortly.
May 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Have an epson photo stylus r310. Won't print even though its saying it is
LEAVE PRINTER ON THEN,
1 remove ALL ink cartridges and close all covers
2 unplug power cord from back of printer
3 wait 4 minutes
4 plug power cord back in and wait for 10 minutes
5 when prompted install ink cartridges and wait a few minutes
click the setup button on the front of the printer scroll down to the tools menu and then run clean print head 3 times and last of all run align printer 1 time.
Jan 30, 2009 | Epson Stylus Photo R300 InkJet Printer
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Ink not compatiable
Hi. When I fitted the second set of cartridges to my Epson Stylus Photo 1400, the printer failed to recognize any of them, even though they were genuine Epson! I repeatedly installed and un-installed them without success. After giving it a bit of thought, I had a hunch that the contacts on the cartridges might not be making good contact with the contacts on the printer as the cartridges seemed a little loose. I removed each cartridge in turn and after putting some adhesive tape on the opposite end to the contacts, (there are grooves cut into this end, but the tape drops nicely into them when you install the cart) replaced them all. (This had the effect of pushing the cartridges harder against the contacts). Switched on again and all carts worked fine. So it seems that even Epson can't make the cartridges to fit their own printer properly! Having said that it's a great printer otherwise. I hope this is helpful to you.
Dec 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
New cartridge inserted but printer says I still need a new one
Jul 27, 2008 | Epson Stylus 1400 InkJet Photo Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
