Question about Jenn-Air JCD2389G Side by Side Refrigerator
Ihave a jenn-air model #JCD2389GE the fan is running but the compressor won"t kick on it clicks and there is a short power surge but it does not turn on
  • Jenn-Air Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
How do i replace the water filter
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2389GES/1266/0165000
Nov 13, 2014 | Jenn-Air Refrigerators
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
Compessor is not kicking on. The freezer began thawing and water dripping out the door. Is there a reset button on the compressor
No reset on compressor. Try controller first, and check all else working e.g. fans lights etc. if power to compressor and not running, time for a new compressor
May 19, 2012 | Jenn-Air JCD2389G Side by Side...
I have water leaking from the bottom. I turned off the water in the back and the problem stopped. Where is the water most likely coming from and how can I repair it? Model #JCD2389GE
Hello
Suspect your main water inlet valves .Usually ,they are behind kick panel bottom front of machine.Look for two small solonoid valves with tubing attached and inspect for leaks.Unplug machine to make repair,there is 120 volts down there.
Hope this helps
Sep 05, 2011 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioner fan comes on then surges for compressor and stops
You can check if theres power to the compresor by pulling the wires off it and turn it on with the volt meter at its terminals if there's power the comprresor is either burned out jamed or grounded.
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
Compressor is not kicking in
Probably power surge shorted out the main board. If so it will need to be replaced. Gotta call for service.
Jun 09, 2008 | Danby Portable Air Conditioner
Jenn-Air JCD2389G Side by Side Refrigerator Logo
215 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
