Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
I just got the Numark iDJ2. It does not recognize my iPOD. I am able to get music on it through USB but now I cannot hear it on the headphones, or when I plug in speakers. Any ideas???
It is a connection miss-wire. Re-read the manual.
Posted on Aug 28, 2010
Idj2 will not recognize my external hard drive
Also try the second port on the back,
try a USB stick with some songs on it, to see if the USB ports are working. If the USB stick works,
Could be the format the External unit is formatted in. Using FAT32 is recommended, look in the manual (downloadable form numark.com) for supported formats.
Preferrable an external HD, which has its own power supply, not fed by the USB ports on the IDJ2 (max 0.5 A)
regard,
Jack
Jan 22, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
I want delete songs from idj2 pls help
There are no songs on the IDJ2
Only on your Harddrive / USb stick or Ipod.
If you want to play songs via the IDJ2, you need the librarian software for using the IDJ2 in combination with you songs.
Dec 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Hi, My IDJ2 plays the music through my headphones and stereo but not at the same time. There is a delay in the stereo output. I have swapped stereos and headphones but no luck.
this is a common problem i have found with several units that have come through our shop. best thing to do is to get it repaired if it is still under warranty. If not ask them how much to repair it. I personally dont like these units but i do love numark. there are multiple videos on youtube explaining how to fix or bypass these with everything from firmware updates to hard mods.
Aug 17, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Idj2 wont recognize ipod after ejecting during library making
Did anyone come up with a solution to this? I'm having the same problem.
May 26, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just bought the Idj2, How do you get the ipod
slot it in the top and it will load to the display
Jan 22, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
My ipod touch does not work if i plug it into the dock or even the USB ports... WHY??
If it is a 2nd Generation iPod Touch it is not supported for use with the idj2. Look at http://www.numark.com/idj2 and review the iPod Compatibility Matrix for further info.
Aug 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just got an idj2. I downloaded the firmware. I went through the library process, though I'm not sure what that really did other than take a ton of time. I hooked my ipod touch (16 gig) to the idj2 and it...
Dan... I hate to be the bearer of bad news...
Located at http://www.numark.com/idj2 there is a link called iPod compatibility matrix v1.6 this link tells you which versions of the iPod work great with the idj2 and which versions of the iPod make you want to pick up your idj2 and smash it against a brick wall. Sadly, the iPod Touch falls into the "smash" catagory.
Generation 1 iPod Touch devices can only be used in "DIRECT MODE ONLY" which means you can use them like a cd player or as a music source on 1 channel of the mixer of the idj2.
Both Generation 1 and Generation 2 iPod Touch devices are not supported to be used with the idj2 in "MASS STORAGE MODE".
Jun 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
How to download firmware and librarian files to my idj2
The current firmware available is version v1.13 which is located at http://www.numark.com/idj2 . It also has Librarian v1.5 included with it.
Download the firmware to your PC and then unzip it to your desktop where you can retrieve it easily.
Transfer the firmware file to the handy little 128mb thumb drive that came with the idj2. (I moved all of the files from the thumb drive on to my PC so the firmware file was the only file on my thumb drive to avoid any computer related confusion)
Making sure your idj2 is powered "OFF" insert the thumb drive containing firmware v1.13 into one of the rear USB ports. Make sure this is the only thing plugged into the idj2 at this time(no keyboard, ect)
Turn on the idj2 on. You will see a message that says the machine is checking the firmware.(I don't have the system in front of me right now but that is roughly what it says) It will take a few minutes and the system will update to the new firmware.
Jun 06, 2009 | Numark iDJ2 Docking Station for Apple iPod...
I recently bought IDJ2, i keep hearing static from my speakers when i plug it in. I have to set the volume on the mixer at a quarter in just so i don't hear the white noice; but the music sounds extremely...
i hav the idj2 and i was expericing the same problems, i am a dj sponsored by numark and they said it's just a little dusty. got to walmart, or your local pc store and pick up an air duster can.unscrew screws located on the bottom of the unit and make shure not to disconnect any wires, then jus blow out all the dust in the inside of the unit, but make shure the air duster dosen't drip on any of the electrical system, make shure you get the usb ports and the ipod dock to then put it back toghter and it should work fine, a temporarry soution i found before i found that is when the static is on turn it of unplugg it and shake it upside down that also helps for the time
May 28, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
IPOD TOUCH DOES NOT PLAY
instead of using your itouch in the ipod deck, plug it to the white cord used to transfer music to your pc, and plug it in the usb dock, it should work because i've tried it with the iphone 3g
Feb 05, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
179 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
