Question about HP Pavilion dv2500t Notebook
My HP Pavillion dv2500t notebook is not booting up properly. It displays the following error "Non-System Disk error or Disk Error."
    Master:
  • 497 Answers
Here's a link that I feel will help you:<br /> <a rel='nofollow' href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372711&amp;lc=en&amp;dlc=en&amp;cc=uk&amp;lang=en&amp;product=3369421">http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372711&amp;lc=en&amp;dlc=en&amp;cc=uk&amp;lang=en&amp;product=3369421</a>
Posted on Aug 28, 2010
How to fix disk controller failure 1782
Try going here http://www.hirensbootcd.org/download/ burn to disk so many useful things.. Run Mini XP
Oct 05, 2014 | HP Compaq 6710b Notebook
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
I/O error
Are you trying to boot the computer through a CD or floppy disk? If not then you have a hard drive problem. I/O errors are caused by a "Non readable disk"
Jul 22, 2012 | Sony VAIO Notebook
Non system disk or disk error
It would appear that your operating system has been corrupted if you're booting from the hard drive. If you're trying to boot from a CD or DVD, the is no operating system on them. This could mean taht your hard drive is failing as well.
Mar 26, 2011 | HP Compaq nc6230 Notebook
Hp labtop non system disk error
Hi, this error most often occurs when you try to boot your computer up with either a flash drive (USB drive) or a CD/DVD already in the computer. The system checks these drives first for operating systems before the hard drive, and when it doesn't find your operating system it displays that error. Remove the disk or flash drive and try to boot your computer again, and the error should go away.
Jan 21, 2011 | HP Computers & Internet
I keep getting the following error even after formatting the machine(windows xp sp3) "Non system disk or disk error, replace and strike any key when ready" ..if i insert an Operating System disk,...
Hello.
I suspect that your hard drive is faulty. If you formatted your drive, due to getting errors, this could be your problem in the first place.
I´d suggest running the hardware diagnostics (usually F2 or F12 upon boot) to see if that info is confirmed).
Hope this helps.
Jan 06, 2011 | HP Compaq nx7010 Notebook
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
System Error
If you have a disk in one of your drives, windows is trying to boot off it. Make sure you haveemptied your drives and then try rebooting.
Jan 11, 2009 | Compaq Evo N610C Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
HP Pavilion dv2500t Notebook Logo
251 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
