Question about D-Link AirPlus DI-524 Wireless Router
Problems with wireless connection
I was able to reset my wireless router and went to the site for D-link to reconfigure my wireless router; however, once I had everything set up, on my wireless connect page it has all bars full but states limited or no activity. When I try to repair it, it states can't renew IP address. What can I do???
  • fitz1718 May 10, 2008
    I tried setting up my router and made it as far as reconfiguring my router. It started giving me a message that says "can not renew IP address". I tried disabling the firewall, resetting the router with the reset button and disconnecting the power. All have failed. I'm not positive as to what I should try next.
  • 298 Answers
Does your network has a security enabled on it?
It's possible that you did not supplied the right security key for on your computer when you tried to connect to your wireless network, that is if its secured. You can also check the firewall on your computer, try to disable them.
Posted on May 07, 2008
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
Went from wildblue internet service to dsl and need to know how reconfigure linksey router
Wildblue is DSL Internet service provider.
You can change the Internet connection settings of Linksys E3000 manually.
Or you can simply reset the router and reconfigure it by running the CD.
See How to setup Linksys E3000
Oct 17, 2011 | Linksys E3000 Wireless Router
I lost internet connection from my compac presario CQ56 and my linksyswrt120n wireless router. Everything was fine the night before. The next morning there was no connection. I think it might be a...
You can try to reset the router and reconfigure it.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it.
Follow this link to configure WRT120N router without CD.
Jul 24, 2011 | Linksys WRT120N Router
I need the website address to reset my router...when I got to 192.168.1.1 it says this is a site for Linksys and is only accessible through their website?? Can you help me?
To reset the wireless router please follow the below procedure.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
192.168.1.1 is the default IP for your wireless Router, Its not hosted any where in the internet.
Jan 01, 2011 | Linksys Wireless-G WRT54G Router
My wireless router is not transmitting a signal. It appears that the connection from boadband modem is working fine. But cannot connect to internet via the router. Need help! krazy_glue
If the router is not transmitting signal the best thing to do here to correct the problem is to reset and and reconfigure the router, to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that power it OFF for 10 seconds and reconfigure it back.......
Dec 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dns problems
If you connect the computer directly to the modem, does it work ?
If not then call ISP and make sure that your main computer will be able to go online when it is connected to the modem only ( without the router).
If that is working then you can reset the routerand reconfigure the router manually.
Click Here to know more about Router set up
Nov 22, 2009 | D-Link AirPlus DI-524 Wireless Router
I need to factory reset my d-link dir 615 due to password problems to use it wirelessly as for some reason my password seems to have changed it self.
Depending on the device, if you still can connect to it using your browser (LAN not wireless), login into the router and in settings go to factory reset. If not, there usually is a small opening on the unit that your can insert a pencil/pen tip to push and do a factory reset that will eliminate your password issue.
If you have not tried a reboot, do that first before doing a factory reset.
Nov 11, 2009 | D-Link DIR-615 Wireless Router
I lost wireless connection and I reset my router and reconfigured it but I was never able to resore connectivity I read about trying different channels but they have been unsuccessful to others ... any...
You said that you reset the router and reconfigured the router.
what is the exact error you are getting while connecting to the wireless network.
Click Here for more info about wireless connection problem.
Oct 06, 2009 | Linksys Wireless-N WRT150N Router
Wrt54g with vista
You can try forwarding ports to secured sites like 443 and 80. There is a possibility that the ports have to be opened on the router. But if the same thing happens, you can try reloading the firmware and reset the router and reconfigure
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Wireless g router wont connect to modem
reset the router holding the button on the back by a pen for least 10 secs. and then connect it to a wired to a port and the computer. ( not the wireless) and now reconfigure with the local ip
http://192.168.2.1
good luck
Aug 11, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
