Question about Refrigerators
Amana fridge section is not cold enough have got it on the highest setting but not working
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Amana BX518VW refrigerator not getting cold enough
Amana is not a S.African make, but all work on the same principle. What i think you have is an evaporator fan motor that is located in the freezer compartment that has jambed up with ice. The freezer needs to be defrosted to allow freezer panel/s to be removed to allow access to the evaporator.Check motor for free movement and if turning freely, switch fridge back on and try and determine if fan comes on. (open door periodically to inspect) If so, replace panel/s and retry. Not sure if you have an auger motor controlling the frost intake to the fridge but if you do, it could also cause problems. Check to see if it can move freelt.
May 20, 2010 | Refrigerators
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge section not cold enough
bad defrost times and or heater look nere the cold control timer is close buy it might be hiddin if you find it use a flat screwdriver and turn it slowly till you here frig turn off and lissn for heaters to come on you will hear them sounds like it shorting out sound
Jun 26, 2009 | Amana ABB2223DES Stainless Steel Bottom...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
